yeap, with firefox and even in a macbook with safari and happen the same.Have you tried with a different web browser?
same...Clear browsers cache, reload the page with Ctrl + F5? Does changing settings work for 5-1 band?
yes, dont save the config, and just happen in 5ghz-2. All the rest 2.4ghz and 5ghz work perfect and can change the settings. how restard httpd in ssh?, thx for the help.Same means? You have similar change/save setting issues across GUI and not 5-2 settings only? Restart httpd in ssh?
I know but i unpdate to 388.2 alpha to try fix this, cuz i was before in to 388.1 merlin and even asus 388 (asus) but same. thx for the help and i read or post in to correct posting.In this case you better report your findings here. You are running unsupported Alpha firmware on your GT-AX11000. It's for testing purposes only.
Hello, i have a problem with the AX-11000, cant use 160mhz in to the 5ghz-2 and even dont let me change mhz or change the channels, all time when i clic in apply dont do nothing.
Mar 18 17:23:02 dnsmasq-dhcp[3026]: DHCPACK(br0) 192.168.50.216 58:bf:25:2d:f2:38 Nuki_Bridge_2D8EF6C3
Mar 18 17:23:20 pppd[1470]: No response to 10 echo-requests
Mar 18 17:23:20 pppd[1470]: Serial link appears to be disconnected.
Mar 18 17:23:20 pppd[1470]: Connect time 1239.6 minutes.
Mar 18 17:23:20 pppd[1470]: Sent 3452072619 bytes, received 1944236686 bytes.
Mar 18 17:23:20 lldpd[1373]: removal request for address of 87.235.0.10%27, but no knowledge of it
Mar 18 17:23:20 wsdd2[3042]: error: wsdd-mcast-v4: wsd_send_soap_msg: send
Mar 18 17:23:20 WAN_Connection: Fail to connect with some issues.
Mar 18 17:23:26 pppd[1470]: Connection terminated.
Mar 18 17:23:26 pppd[1470]: Sent PADT
Mar 18 17:23:26 pppd[1470]: Modem hangup
Mar 18 17:23:30 vnstatd[3834]: Interface "ppp0" disabled.
Mar 18 17:23:33 awsiot[467854]: awsiot start
Mar 18 17:24:11 pppd[1470]: Timeout waiting for PADO packets
Mar 18 17:25:26 pppd[1470]: Timeout waiting for PADO packets
Mar 18 17:26:40 pppd[1470]: Timeout waiting for PADO packets
Mar 18 17:27:55 pppd[1470]: Timeout waiting for PADO packets
Mar 18 17:29:10 pppd[1470]: Timeout waiting for PADO packets
Hi, sorry but work before many time
Yeah i know, right now i disable the 5ghz-2 and work at 160mhz ax11000 and ax82u in aimesh and its ok i think. just hope soon resolve this problems, the more important i think its fix the openvpn cuz drop the internet connection if i enable the openvpn. thx to everyone for the help.You may have to revert to what was known working firmware and wait for a fix. There is nothing much to be done at this point.
I wouldn't use 160MHz wide channels at all. Non-DFS and 80MHz wide channels for more stability.
Welcome To SNBForums
