Problem with disable Nats on AC68U
frankly
i install merlin v. 380.57 on my ac68u and my speed is ~10 Mbit down, 4 Mbit up with openvpn.
My ISP speed is 50 Mbit down, 20 Mbit up.
Is this problem fixed in v. 380.57 or must i go back to v. 378.56 for more vpn-speed:
From a another forum:
There seems to be a bug with the rt-68u and some CTF's that cause these slow speeds.
Make sure you are using port 1196 and AES-128-CBC and then disabling NAT acceleration under LAN > Switch control.
I re-share this here in case any other Asus RT-AC68 (plus Merlin firmware) users are banging their heads against the wall in search of the solution, as was I.
Before you disable NAT acceleration, you'll need to revert to Merlin 378.56.
Otherwise, due to a bug in the latest Merlin version, you'll lose your 2.4 GHz wireless network (i.e., it appears to wireless devices but doesn't function once a device connects).
To disable NAT acceleration, in the Merlin admin panel go to LAN > Switch control, and turn off NAT Acceleration. Doing so should instantly give you full ISP speed (whether via TCP or UDP).
I wish for the next merlin firmware vpn ikev1 and ikev2 was include. PLEASE!!!!!!
Greetings
