Problem with Download Master in current versions
felisima
Hi.
I am using the router RT-AC87U
I have already reset it from the factory several times.
I configure it manually. I do not use a saved configuration file.
I have verified that in the version 380.69_2 of Asuswrt-Merlin, the Download Master works correctly.
But in current versions such as version 384.11, the Download Master gives errors when you try to use it.
Could you check what I say and try to solve the problem?
Greetings and thanks for the help.
Hi.
Welcome to the forums! :)
What router are you using? Did you do a full reset to factory defaults followed by a minimal and manual configuration (do not use a saved config file) to secure the router and connect to your ISP?
Please see my signature below to the M&M Config guide to get your router to a good/known state first.
I am using the router RT-AC87U.
The order the reset is done is important. See the M&M Config link in my signature below and compare your steps with my suggestions.
The errors you get would also be helpful to post too. :)
I also encourage you to search on the forum here for posts with similar issues using download master.
