Problem with RT-N66U after firmware update
gollymister
So I just recently updated my RT-N66U router to the firmware that was released in june. Now, the router says that there are errors on my 2TB hard drive (it has its own power adapter and is NTFS formatted), one of my macs doesn't see anything that's connected to the network, and my windows computer can't see the hard drive in the network folder. I ran the chkdsk command on the hard drive, and it said there aren't any problems. Any help would be appreciated.:D
here's the disk scan results:
GetMount: "/dev/sda1"
GetMount: Device is not mounted
Checking Volume /dev/sda1...
Type of the filesystem is NTFS.
Volume label is: Network
0%
Verifying 256 records ...
100%
0%
Verifying 11 folders ...
100%
0%
Verifying files security...
100%
$UpCase file is formatted for use in Windows 7
113984 KB in 16 files
12 KB in 13 directories
0 KB in bad blocks in 0 fragments
185448 KB in use by the system
65536 KB occupied by the log file
2048 bytes in each allocation unit
976755711 total allocation units on volume
976605995 allocation units available on volume
The volume /dev/sda1 appears to be OK.
chkntfs returns 1
and here's the relevant system log entries:
Jul 10 17:33:26 rc_service: httpd 348:notify_rc start_diskscan
Jul 10 17:33:26 disk monitor: start...
Jul 10 17:33:26 disk monitor: unmount partition
Jul 10 17:33:26 syslog: USB partition unmounted from /tmp/mnt/Network
Jul 10 17:33:26 disk monitor: scan partition
Jul 10 17:34:46 disk monitor: re-mount partition
Jul 10 17:34:46 syslog: USB /dev/sda1(ntfs) failed to mount at the first try!
Jul 10 17:34:46 kernel: ufsd: use builtin utf8 instead of kernel utf8
Jul 10 17:35:04 kernel: ufsd: sda1 without journal
Jul 10 17:35:04 syslog: USB ntfs fs at /dev/sda1 mounted on /tmp/mnt/Network
Jul 10 17:35:04 rc_service: disk_monitor 523:notify_rc start_samba
Jul 10 17:35:04 rc_service: disk_monitor 523:notify_rc start_ftpd
Jul 10 17:35:04 rc_service: waitting "start_samba" via disk_monitor ...
Jul 10 17:35:05 Samba Server: daemon is started
Jul 10 17:35:05 smbd[1182]: [2014/07/10 17:35:05, 0] /home/defjovi/projects/asuswrt/release/src/router/samba3/source/lib/pidfile.c: pidfile_create(116)
Jul 10 17:35:05 smbd[1182]: ERROR: smbd is already running. File /var/run/samba/smbd.pid exists and process id 796 is running.
Jul 10 17:35:05 nmbd[1183]: [2014/07/10 17:35:05, 0] /home/defjovi/projects/asuswrt/release/src/router/samba3/source/lib/pidfile.c: pidfile_create(116)
Jul 10 17:35:05 nmbd[1183]: ERROR: nmbd is already running. File /var/run/samba/nmbd.pid exists and process id 795 is running.
Jul 10 17:35:05 rc_service: disk_monitor 523:notify_rc start_dms
Jul 10 17:35:05 rc_service: waitting "start_ftpd" via disk_monitor ...
Jul 10 17:35:05 start_nat_rules: apply the nat_rules(/tmp/nat_rules_eth0_eth0)!
Jul 10 17:35:06 rc_service: disk_monitor 523:notify_rc start_mt_daapd
Jul 10 17:35:06 rc_service: waitting "start_dms" via disk_monitor ...
Jul 10 17:35:07 disk monitor: done
Jul 10 17:35:17 disk monitor: be idle
Jul 10 17:36:03 kernel: usb 1-1.2: USB disconnect, address 6
Jul 10 17:36:03 rc_service: hotplug 1213:notify_rc restart_nasapps
Jul 10 17:36:03 FTP Server: daemon is stoped
Jul 10 17:36:03 hotplug[1215]: USB partition unmounted from /tmp/mnt/Network
Jul 10 17:36:03 rc_service: hotplug 1215:notify_rc restart_nasapps
Jul 10 17:36:03 rc_service: waitting "restart_nasapps" via ...
Jul 10 17:36:03 Samba Server: smb daemon is stoped
Jul 10 17:36:04 FTP Server: daemon is stoped
Jul 10 17:36:04 Samba Server: smb daemon is stoped
Jul 10 17:36:29 kernel: usb 1-1.2: new high speed USB device using ehci_hcd and address 7
Jul 10 17:36:29 kernel: usb 1-1.2: configuration #1 chosen from 1 choice
Jul 10 17:36:29 kernel: scsi4 : SCSI emulation for USB Mass Storage devices
Jul 10 17:36:31 kernel: scsi 4:0:0:0: Direct-Access WD Ext HDD 1021 2021 PQ: 0 ANSI: 4
Jul 10 17:36:31 kernel: sd 4:0:0:0: [sda] 3907024896 512-byte hardware sectors (2000397 MB)
Jul 10 17:36:31 kernel: sd 4:0:0:0: [sda] Write Protect is off
Jul 10 17:36:31 kernel: sd 4:0:0:0: [sda] Assuming drive cache: write through
Jul 10 17:36:31 kernel: sda: sda1
Jul 10 17:36:31 kernel: sd 4:0:0:0: [sda] Attached SCSI disk
Jul 10 17:36:31 kernel: sd 4:0:0:0: Attached scsi generic sg0 type 0
Jul 10 17:36:31 hotplug[1248]: USB /dev/sda1(ntfs) failed to mount at the first try!
Jul 10 17:36:31 kernel: ufsd: use builtin utf8 instead of kernel utf8
Jul 10 17:36:50 kernel: ufsd: sda1 without journal
Jul 10 17:36:50 hotplug[1248]: USB ntfs fs at /dev/sda1 mounted on /tmp/mnt/Network
Jul 10 17:36:50 rc_service: hotplug 1248:notify_rc restart_nasapps
Jul 10 17:36:50 FTP Server: daemon is stoped
Jul 10 17:36:50 Samba Server: smb daemon is stoped
Jul 10 17:36:51 Samba Server: daemon is started
THANK YOU!
If I were you, I'd go back to the previous f/w and see what happens to prove it is caused by your update.
so my hard drive is now visible after I did nothing....weird, but it still says that there are errors on it. I'm going to put all of the old data on it before I just go back to the old firmware. Hopefully, that'll fix it.
Did you reset to defaults before and after the upgrade? Try that before reverting to the old firmware. Configuration data can survive firmware upgrades and cause all sorts of havoc.
Update firmware with out any USB devices connected to the router.
Reset.router.
Set.it up.
Attach USB hard drive.
