y2kbug
RT-AC87R with Firmware Version:384.4_2
Using "www.asus.com" as DDNS service provider, it works together with LetsEncrypt.
However, using NameCheap, the IP is updated, but LetsEncrypt fails.
"Remote Access" and "HTTPS" is turned on.
"HTTPS Port of Web Access from WAN" is set to be 443.
"AiCloud" is set to something else.
I see something strange in the "Local Access Config" section.
The label after "HTTPS LAN Port" is "Access setting page via https://a.b.c:443" (I filter it. It is a correct and accessable url)
The label after "HTTPS Port of Web Access from WAN" is "Access setting page via https://a:443"
So I suspect the firmware handle the Namecheap parameters wrongly.
Below is the log:
Mar 31 00:07:54 watchdog: start ddns.
Mar 31 00:07:54 rc_service: watchdog 297:notify_rc start_ddns
Mar 31 00:07:54 start_ddns: update WWW.NAMECHEAP.COM namecheap, wan_unit 0
Mar 31 00:07:54 ddns_update: ez-ipupdate: starting...
Mar 31 00:07:54 ddns_update: connected to dynamicdns.park-your-domain.com (104.219.249.157) on port 80.
Mar 31 00:07:55 ddns_update: request successful
Mar 31 00:07:55 ddns_update: asusddns_update: 0
Mar 31 00:07:55 ddns: ddns update ok
Mar 31 00:08:02 kernel: /usr/sbin/acme-client: https://acme-v01.api.letsencrypt.org/acme/new-authz: bad HTTP: 400
Mar 31 00:08:02 kernel: /usr/sbin/acme-client: transfer buffer: [{ "type": "urn:acme:error:malformed", "detail": "Error creating new authz :: DNS name does not have enough labels", "status": 400 }] (137 bytes)
I am not sure if this is the correct place to report but.
If not, may anyone please instruct me who I can report to?
Thank you very much.
Below is the log:
