Let me explain my setup to you guys, and hopefully someone smart and kind will be able to assist me!
Modem ------> AC68U <==========> AC66U
---------> = Cable
<====> = 5 GHz wireless
I run two networks, "1336" is 2.4 GHz and "1337" is 5 GHz. My AC68U is set up as a "Wireless Router", and the AC66U is set up in "Repeater Mode". The AC66U repeats the 1337 network.
Devices can roam between them on 1336 just fine, but when on 1337, it is another story. When the device is closest to AC66U, it cannot connect to it, like it's getting rejected for some reason. And when AC68U has best signal, it works just fine! The same thing is happening on ALL my devices.
I'm running the newest Merlin firmware on both of them.
Also have a small question, why do they only connect between eachother with 866,5 Gbit/s, even when I moved them 5 meters away from eachother?
Thanks for reading this!
Edit: to clarify, only thing that doesn't work is the repeated 5 GHz network from the AC66U (it connects to AC68U just fine and repeats the signal just fine via LAN and 2.4 GHz)
---------> = Cable
