which one is better for a Link upto 73meters.
2X 2.4GHz 6dBi Indoor Directional Antenna
TL-ANT2406A
http://www.tp-link.us/products/details/?model=TL-ANT2406A#spec
Or
1X 2.4GHz 9dBi Directional Antenna
TL-ANT2409A
or
will a
2.4GHz 8dBi Indoor Omni-directional Antenna
TL-ANT2408CL http://www.tp-link.us/products/details/?categoryid=2473&model=TL-ANT2408CL#spec
+ 2.4GHz 6dBi Indoor Directional Antenna
TL-ANT2406A
will work ?
Currently I'm using
TL-ANT2406A
+ Default 5dbi antenna
Signal strength ~40% as mentioned in Gargoyle.
Tp-link 741ND on both ends.
Also firmware should be used for this link ? gargoyle doesn't have things like ACK timing etc.
_________________
TL-ANT2406A
Or
TL-ANT2409A
or
will a
TL-ANT2406A
will work ?
Currently I'm using
TL-ANT2406A
_________________
