RT-AX86U Pro, Firmware Version:3.0.0.6.102_34336
I setup a Guest Network Pro IOT Network for my Home Automation devices (mainly sensors, bulbs, a few goggle mini / home etc.).
The IOT network has main sub-net, runs on 2.4g network and no VPN or VLAN.
I am getting failure in adding new devices to my tuya app. I see the device but addition fails. Note: the phone with the app is on the Guest IOT Network.
Now I think it many be due to some configurations of the IOT network (like access to intranet etc.) but I don't see those settings for thsi automatically created network. So I am thinking up of setting up a custom guest network. so that I can control all those settings.
Q 1) if I create a Guest Network that has the same setting the current IOT network, will they be same?
OR does the automated Guest IOT Network add some settings/ configurations which are not visible and not set-able on the GUI when I create a custom guest network.
Q2) Is it advisable to run a separate subnet & VLAN for the IOT devices? Internet access but no intranet access.
Q3) Any recommendations on setting up a network for IOT devices
