Qnap tvs-471 ram upgrade
jjulez
Anyone have this unit and done the ram upgrade ?
Outer ram slot is very easy to install,inner slot no space for
a hand to move around.
QNAP's Web Site has manuals for the hardware - so check there..
Check other models that are similar - basically, some disassembly will likely be required unless one has elfin hands, and even then, elves likely can't make it happen...
