sdmf74
Doesn’t matter. Just an accuracy boost under uncommon corcumstances.
Is this the answer to my question about the ATM tick box?
It's an ADSL overhead.Is this the answer to my question about the ATM tick box?
Doesn’t apply to DOCSISIt's an ADSL overhead.
I know that's what I said lolDoesn’t apply to DOCSIS
Quoted the wrong post hahaI know that's what I said lol
All good no biggie.Quoted the wrong post haha
I've finally installed Merlin and I'm changing my QOS settings when I chose fq_codel and the WAN Packet overhead box opened up. Every-time I select Cable (DOCSIS) preset and hit apply it jumps back to 'Select preset:' ??? I've tried setting it to cable 2-3 times now and it keeps jumping back. Is it broken?
EDIT: I just tried ticking the checkbox for ATM (18) and it still didn't hold.
All the preset dropdown does is enter pre-configured values in the two fields. It's not a setting in itself, so it will always revert back to "Select a preset", just like presets on the Virtual Servers page.
Playing around with this a bit more, what do I pick for Wan overhead packet for 1 gig Fibre connection? ( ISP: Telus ) -- and I should choose between 0 and 18 - what is ATM, should I check that?
No Modem - direct to AC86U
Why do you feel you need Adaptive QoS on a symmetric 950/950 connection?
Actually I don't, I just thought its better, sorry no idea on this so no need of QOS ?
No need.
If you did use it though, you would leave the ATM at zero for your connection.![]()
No need for QoS on such a powerful Internet connection. I wish I could get symmetric 950/950 in my middle-of-nowhere neighborhood.![]()
But bufferfloat is rated from B to C
I believe you would select Ethernet for this scenario.Playing around with this a bit more, what do I pick for Wan overhead packet for 1 gig Fibre connection? ( ISP: Telus ) -- and I should choose between 0 and 18 - what is ATM, should I check that?
You're using dslreports.com Speed Test for that grading right? Would you mind posting a screenshot of the actual graphs it shows in "Results"? Usually there is a bar graph with 3 bars, and if you mouse over them it shows very millisecond (ms) results.
Also, try this as a bufferbloat test: https://www.fast.com
The key is to click "Show More Info" after the initial speed test, and paste the "Latency - Loaded" result. (or just everything).
Welcome To SNBForums
