TheLyppardMan
The filtered results in QoS Web History don't seem to be working correctly for all network devices. For instance, my own computer just shows everything and not even in any particular order.
I can't change the displayed list, no matter what I try.Look at the Domain Name column (not show on your images) : sorted ascending on that field.
There is no way to sort with those headers that I can see.Look at the Domain Name column (not show on your images) : sorted ascending on that field.
It does appear to work for some devices as they show only sites that they would logically access but with other devices, it can show nothing or a whole array of sites that the devices have connected to, some that don't make sense to me such as why would a Fire TV be connecting to a windowsupdate server.
I am not confident at all that I understand how this feature works or even if it's even working properly.
But would they even reply if they get a hint that we're using Merlin's firmware? Just to clarify, is anyone able to confirm whether or not this is working with the ASUS official firmware? I'm going to have a look in their part of the forum to see if I can find anything.Thanks.
So if answers are needed then it's Asus that needs to be questioned.
If it were really working correctly then the client selection filter would make a difference, but it doesn't.Everyone claiming it doesn’t work has to understand that it’s sorted in alphabetical order by domain name rather than chronological order.
Welcome To SNBForums
