Question/favor for the ZenWiFi users group...
Viktor Jaep
Part of the Furniture
I'm trying to determine the actual ZenWifi router model name that's stuck inside your NVRAM so I can query it correctly within RTRMON... and for those of you willing, was hoping if you could please run a quick command for me to confirm?
If you are running one of these models:
  • ZenWiFi Pro XT12 Done!
  • ZenWiFi XT8 Done!
  • ZenWiFi ET8
Please open an SSH prompt, and please run these 2 commands, and drop your results in the thread below:
nvram get odmpid
nvram get productid
Thank you so much! ;) (This is unfortunately the downside of not having a plethora of routers to test with) lol
ASUSWRT-Merlin XT12 3004.388.7_0 Fri Apr 26 18:22:46 UTC 2024
Rafal@XT12-G:/tmp/home/root# nvram get odmpid
ZenWiFi_Pro_XT12
Rafal@XT12-G:/tmp/home/root# nvram get productid
XT12
ZenWiFi_Pro_XT12
XT12
Very much appreciated!! :)
nvram get odmpid
ZenWiFi_XT8
nvram get productid
RT-AX95Q
For grins @GratefulEight & @ligeza ... what do you get when you run these 2 statements?
[ -z "$(nvram get odmpid)" ] && RouterModel="$(nvram get productid)" || RouterModel="$(nvram get odmpid)"
echo "$RouterModel"
Rafal@XT12-G:/tmp/home/root# [ -z "$(nvram get odmpid)" ] && RouterModel="$(nvram get productid)" || RouterModel="$(nvram get odmpid)"
Rafal@XT12-G:/tmp/home/root# echo "$RouterModel"
ZenWiFi_Pro_XT12
  • ZenWiFi XT8 Done!
  • ZenWiFi ET8
nvram get odmpid
nvram get productid
nvram get odmpid: ZenWiFi_ET8
nvram get productid: RT-AXE95Q
