Things I learned about my RT-BE88U AiMesh routers
Explore SMB options with native VLAN support and you'll be happier.
Don't you worry about my happiness. This is the route I chose to follow, and follow it I will.
I'm really pleased I've never experienced any of the problems you seem to have.
Your router must have hardware faults, or your factory reset didn't complete.
Are you running it in router mode, or AP mode? Are you using a VLAN setup?
Both my units are displaying the exact same configuration issue behaviour, so we can rule out a hardware defect I recon.
Router mode. VLAN + VPN on an IoT guest network.
Pointing your anger to people trying to help you won't solve your problem. Good luck!
Not sure what your problem is. As stated before, I'll solve the issues myself, I am just sharing my experiences (and occasional rage) here.
For the completeness of things, this is the end solution to get the correct wireless subinterfaces assigned to the correct bridge interfaces (when using the GUI to create VLANs and assign SSIDs to it), as well as using a different VLAN for the management of the AP:
Check NVRAM to see which wireless sub interface is assigned to your SSID: nvram show | grep -i wl | grep -i ssid
Add script to /jffs/scripts, name it 'services-start', make sure to chmod +x the file.
Adjust config to your situation.
#!/bin/bash
# remove untagged traffic from br0
brctl delif br0 eth0
brctl delif br0 eth9
# move management to VLAN 2 on br2
ifconfig br0 0.0.0.0
ifconfig br2 xx.xx.xx.xx netmask 255.255.255.0
route add default gw xx.xx.xx.xx
# remove all wireless sub interfaces assigned after configuring them via GUI
brctl delif br0 wl0.0
brctl delif br0 wl1.0
brctl delif br0 wl0.4
brctl delif br0 wl0.1
brctl delif br0 wl1.1
brctl delif br2 wl0.2
brctl delif br2 wl1.2
brctl delif br3 wl0.3
brctl delif br3 wl1.3
brctl delif br4 wl1.4
brctl delif br5 wl0.5
brctl delif br5 wl1.5
brctl delif br6 wl0.6
brctl delif br6 wl1.6
# assign wireless sub interfaces to the correct bridges
brctl addif br3 wl0.1
brctl addif br3 wl1.1
brctl addif br4 wl0.2
brctl addif br4 wl1.2
brctl addif br6 wl0.3
brctl addif br6 wl1.3
Be careful, /jffs/scripts/services-start may already exist as a few addons use it. The script above can be added to it though.
@vlanvlan how many vlans have you set up on your router between the last reset and turning it into an AP? I ask because mine (in router mode of course) is only running two bridges - br0 (for the main network) and br55 (for VLAN52). I can't understand why you have so many just by changing to AP mode. And yes, my nvram contains all those wl settings (with different values of course).
I use 5 VLANs inside my house with an upstream firewall, VLAN ID's 2 through 6. Default the AP starts dishing out VLANs in the 50's range when you just select the different subnet option on creating an SSID. You are however able to manually create your own list of IDs, or reassign the one it has given you, if you have any need for it. I am suspecting ASUS has not tested for the situation where its users want to use the lower range of VLAN IDs.
Just came across this post - great info...thanks for taking the time to create it.
I picked up a RT-AX86U PRO and have been playing around with it (in AP mode) and OPNsense in a test lab scenario before I convert it to my live home network; specifically playing around with VLAN's and looking under the hood at how the software is setting them up.
I started with ASUS firmware (GUI supports VLAN's for the PRO model) and explored setup as you have done with the various commands. I then switched to Merlin 3004 code which does not have the GUI for VLAN's and found a lot of great posts here on setting up VLAN's and such...cool stuff trying different commands and attempting to match output/outcomes from the ASUS firmware.
Occasionally check for updates and came across recent Alpha version for the PRO model based on the 3006 firmware so loaded that up - pretty awesome...thanks @RMerlin and team! Now playing around with it (it is running great BTW with 4 VLAN's) and comparing that output to the other data I have collected...love looking "under the hood" to see how things work.
Great feedback, thanks.
If you ever get to adding Manual Assignments for e.g. an IoT VLAN (which tend to have numerous devices) I would be interested to see if you hit a limit as I did, thanks. I never got to the maximum of 32.
I am also waiting to find out where you can save the assignments for VLANs for re-importing back in to the configuration, like you can currently do for the Primary LAN (only).
"The 10G interfaces (RJ45+SFP) are one and the same interface, cannot be used both"
Euhm no? I have the 10G RJ45 interface connected to the WAN/ISP and the 10G SFP+ to an internal switch.
I hadn't touched my devices for a while. Now I had time again so I figured I do some more tinkering with it after a few more firmware versions were released. It just occurred to me that, at least when set in AP mode, the wired 10G WAN/LAN port cannot be configured via the GUI. Under 'advanced settings -> LAN' this port doesn't show up. Is this any different when running the device in router mode?
