Carnagerover
Hi all,
I am having trouble with the R7000 at the ability to be able to see local servers, for example.
When I use Splashtop I can connect locally on a fresh reboot and then after a few days it will only work if I log in and connect over the internet. Also I have a Plex server on my PC and that can only see my local server if I log into my Plex account which shouldn't be necessary, this problem only seems to effect one iPad for some reason and not the others.
What affects the routers ability to do these things, as rebooting my PC or iPad doesn't fix the issue only a router reboot does?
