I've read the other posts in this forum from circa 2014 but this sounds kind of different. I purchased this router about 4 years ago and it has been completely silent up until today. We had a quick brownout, everything powered back up and all was fine. I had purchased a UPS a while back and decided it was probably a good time to plug things into the UPS.
When I plugged the R7000 into the UPS, on power up it started making a hiss/buzz noise loud enough to be heard in the next room. I have a fan running on high in my office and I can still hear it. I moved the R7000 plug back to the powerstrip it was plugged into before and it's still hissing.
I disabled both the 5GHz radio (hissing volume dropped by about 50%) then the 2.4GHz radio (nothing changed). So even with both wifi radios disabled, it's still hissing.
Everything seems to be working OK, but this noise is going to drive me nuts. There's really no solution for this? Netgear claims a router without a fan or any moving parts making noise is normal?!?? That doesn't seem like something that would be normal at all.
I have a bunch of WAPs around the house, so if disabling the radios would stop the noise, I could live with that, but that's not working.
