R7800 lost 5GHz SSID :(
Back to channel 44 then, as it always was before.
It had jumped from channel 56 to channel 128 during the night...
Yes, I do it on a regular basis with the various Xfinity gateways. Occasionally there may be the odd iOT device that requires a power cycle to re-establish the connection.
It's weird. I thought that because of the new MacAddress of the router, the devices wouldn't connect anymore.
So if I were to change my router (that's working again so far) and get an Asus ASUS ROG GT-AX6000, and if I would use the same SSID and the same password, all my devices would connect automatically to the router ? I wouldn't have to configure them again ?
MAC address of the AP has no effect on clients being able to reconnect.
I've changed my WiFi APs several times over the years and kept the same SSID / password. I've never had to configure clients again, they always connect automatically.
I am going to take issue with your use of the word ALL. There may be an occasional iOT or other device that does not conform. You may have to power cycle this device or maybe even reset the connection. Your two R7800 routers definitely had two different MAC addresses.
