[R7800] RAE, cloudfront ??? Netgear snitch?
:cool: You made the same error... same in sbin.
I've added all these good "blocks" to my add-on, so those of you that don't excel in command lines can disable these things.
Watch out tomorrow...
I also followed your suggestion for adding the code to post-mount.sh
But today I noticed traffic-meter was still running. After some checking, I found out that you have a typo. the correct command to stop traffic-meter would be:
[ -x /sbin/traffic-meter ] && { /etc/init.d/traffic_meter stop; chmod -x /sbin/traffic-meter; ps|grep -F '/sbin/traffic-meter'|awk '{print $1}'|xargs kill 2>/dev/null; }
(the init script is with an underscore instead of a hyphen)
And there are other errors as well. But who cares? Let's have fun and improve together!
Errae humanum est, or what they said. I'm not a Messerschmidt!
So line for traffic_meter should be:
[ -x /sbin/traffic_meter ] && { chmod -x /sbin/traffic_meter; /etc/init.d/traffic_meter stop; }
The ps, grep, kill... is probably not necessary then.
I see what you mean, but this is not necessarily true as the command is made from the init.d script that is different from the sbin executable.
I know it works in this order for aws-iot.
I haven’t tried yet with traffic_meter, but next firmware upgrade will tell ;)
you should do the stop *before* you make the script non-execute
Sounds great, my general point was I like stopping first then marking non-execute, that's all.
If it works already then moot point.
