Random Crash on AC-68U
airbusltd
Hi, I am currently using Merlin 378.55 firmware on my AC-68U and is experiencing random crash issue.... The router is placed inside a air-conditioning room so it isn't related to overheating. I cannot login the the router GUI once it crash. The only way is to reboot the router manually. Anyone can help on this problem? Here is the log before and after the crash. Thanks in advance.
(Due to the limitation of 10,000 characters, I have split the log into 3 parts. Please view the following reply for the remaining log.)
Oct 22 18:39:56 dnsmasq-dhcp[488]: DHCPDISCOVER(br0) 34:xx:xx:xx:xx:61
Oct 22 18:39:56 dnsmasq-dhcp[488]: DHCPOFFER(br0) 192.168.1.95 34:xx:xx:xx:xx:61
Oct 22 18:39:57 dnsmasq-dhcp[488]: DHCPREQUEST(br0) 192.168.1.95 34:xx:xx:xx:xx:61
Oct 22 18:39:57 dnsmasq-dhcp[488]: DHCPACK(br0) 192.168.1.95 34:xx:xx:xx:xx:61 iPad
Oct 22 19:07:34 dnsmasq-dhcp[488]: DHCPREQUEST(br0) 192.168.1.95 34:xx:xx:xx:xx:61
Oct 22 19:07:34 dnsmasq-dhcp[488]: DHCPACK(br0) 192.168.1.95 34:xx:xx:xx:xx:61 iPad
Jan  1 08:00:15 syslogd started: BusyBox v1.20.2
Jan  1 08:00:15 kernel: klogd started: BusyBox v1.20.2 (2015-07-16 23:17:03 EDT)
Jan  1 08:00:15 kernel: Linux version 2.6.36.4brcmarm (merlin@mint-dev) (gcc version 4.5.3 (Buildroot 2012.02) ) #1 SMP PREEMPT Thu Jul 16 23:26:07 EDT 2015
Jan  1 08:00:15 kernel: CPU: ARMv7 Processor [413fc090] revision 0 (ARMv7), cr=10c53c7f
Jan  1 08:00:15 kernel: CPU: VIPT nonaliasing data cache, VIPT nonaliasing instruction cache
Jan  1 08:00:15 kernel: Machine: Northstar Prototype
Jan  1 08:00:15 kernel: Ignoring unrecognised tag 0x00000000
Jan  1 08:00:15 kernel: bootconsole [earlycon0] enabled
Jan  1 08:00:15 kernel: Memory policy: ECC disabled, Data cache writealloc
Jan  1 08:00:15 kernel: MPCORE found at 19020000
Jan  1 08:00:15 sd-idle-2.6[384]: initialized
Jan  1 08:00:15 kernel: PERCPU: Embedded 7 pages/cpu @c8215000 s5472 r8192 d15008 u65536
Jan  1 08:00:15 kernel: pcpu-alloc: s5472 r8192 d15008 u65536 alloc=16*4096
Jan  1 08:00:16 kernel: pcpu-alloc: [0] 0 [0] 1
Jan  1 08:00:16 kernel: Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 60416
Jan  1 08:00:16 kernel: Kernel command line: root=/dev/mtdblock2 console=ttyS0,115200 init=/sbin/preinit earlyprintk debug
Jan  1 08:00:16 kernel: PID hash Table entries: 1024 (order: 0, 4096 bytes)
Jan  1 08:00:16 kernel: Dentry cache hash Table entries: 32768 (order: 5, 131072 bytes)
Jan  1 08:00:16 kernel: Inode-cache hash Table entries: 16384 (order: 4, 65536 bytes)
Jan  1 08:00:16 kernel: Memory: 128MB 128MB = 256MB total
Jan  1 08:00:16 kernel: Memory: 255520k/255520k available, 6624k reserved, 0K highmem
Jan  1 08:00:16 kernel: Virtual kernel memory layout:
Jan  1 08:00:16 kernel:  vector  : 0xffff0000 - 0xffff1000  (  4 kB)
Jan  1 08:00:16 kernel:  fixmap  : 0xfff00000 - 0xfffe0000  ( 896 kB)
Jan  1 08:00:16 kernel:  DMA  : 0xf7e00000 - 0xffe00000  ( 128 MB)
Jan  1 08:00:16 kernel:  vmalloc : 0xd0800000 - 0xf0000000  ( 504 MB)
Jan  1 08:00:16 kernel:  lowmem  : 0xc0000000 - 0xd0000000  ( 256 MB)
Jan  1 08:00:16 kernel:  modules : 0xbf000000 - 0xc0000000  (  16 MB)
Jan  1 08:00:16 kernel:  .init : 0xc0008000 - 0xc003d000  ( 212 kB)
Jan  1 08:00:16 kernel:  .text : 0xc003d000 - 0xc03a4000  (3484 kB)
Jan  1 08:00:16 kernel:  .data : 0xc03bc000 - 0xc03df000  ( 140 kB)
Jan  1 08:00:16 kernel: SLUB: Genslabs=11, HWalign=32, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
Jan  1 08:00:16 kernel: * Invalid signature of oopsbuf: FF-FF-DF-FF-FF-FD-FF-FF (len 4294901759)
Jan  1 08:00:16 kernel: Hierarchical RCU implementation.
Jan  1 08:00:16 kernel:    RCU-based detection of stalled CPUs is disabled.
Jan  1 08:00:16 kernel:    Verbose stalled-CPUs detection is disabled.
Jan  1 08:00:16 kernel: NR_IRQS:256
Jan  1 08:00:16 kernel: MPCORE GIC init
Jan  1 08:00:16 kernel: External imprecise Data abort at addr=0x0, fsr=0x1c06 ignored.
Jan  1 08:00:16 kernel: MPCORE Global Timer Clock 400000000Hz
Jan  1 08:00:16 kernel: Calibrating delay loop... 1599.07 BogoMIPS (lpj=7995392)
Jan  1 08:00:16 kernel: pid_max: default: 32768 minimum: 301
Jan  1 08:00:16 kernel: Mount-cache hash Table entries: 512
Jan  1 08:00:16 kernel: CPU: Testing write buffer coherency: ok
Jan  1 08:00:16 kernel: MPCORE Private timer setup CPU0
Jan  1 08:00:16 kernel: Calibrating local timer... 399.876MHz.
Jan  1 08:00:16 kernel: L310: cache controller enabled 16 ways, CACHE_ID 0x410000c8, AUX_CTRL 0x7a130000
Jan  1 08:00:16 kernel: CPU1: Booted secondary processor
Jan  1 08:00:16 kernel: MPCORE Private timer setup CPU1
Jan  1 08:00:16 kernel: Brought up 2 CPUs
Jan  1 08:00:16 kernel: SMP: Total of 2 processors activated (3198.15 BogoMIPS).
Jan  1 08:00:16 kernel: devtmpfs: initialized
Jan  1 08:00:16 kernel: atomic64 test passed
Jan  1 08:00:16 kernel: NET: Registered protocol family 16
Jan  1 08:00:16 kernel: Found a AMD NAND flash:
Jan  1 08:00:16 kernel: Total size:  128MB
Jan  1 08:00:16 kernel: Block size:  128KB
Jan  1 08:00:16 kernel: Page Size:  2048B
Jan  1 08:00:16 kernel: OOB Size:  64B
Jan  1 08:00:16 kernel: Sector size: 512B
Jan  1 08:00:16 kernel: Spare size:  16B
Jan  1 08:00:16 kernel: ECC level:  8 (8-bit)
Jan  1 08:00:16 kernel: Device ID: 0x 1 0xf1 0x80 0x1d 0x 1 0xf1
Jan  1 08:00:16 kernel: CCA UART Clock Config: Sel=1 Ovr=1 Div=48
Jan  1 08:00:16 kernel: CCA UART Clock rate 100000000Hz
Jan  1 08:00:16 kernel: bio: create slab <bio-0> at 0
Jan  1 08:00:16 kernel: Switching to clocksource mpcore_gtimer
Jan  1 08:00:16 kernel: NET: Registered protocol family 2
Jan  1 08:00:16 kernel: IP route cache hash Table entries: 2048 (order: 1, 8192 bytes)
Jan  1 08:00:16 kernel: TCP esTablished hash Table entries: 8192 (order: 4, 65536 bytes)
Jan  1 08:00:16 kernel: TCP bind hash Table entries: 8192 (order: 4, 98304 bytes)
Jan  1 08:00:16 kernel: TCP: Hash Tables configured (esTablished 8192 bind 8192)
Jan  1 08:00:16 kernel: TCP reno registered
Jan  1 08:00:16 kernel: UDP hash Table entries: 128 (order: 0, 4096 bytes)
Jan  1 08:00:16 kernel: UDP-Lite hash Table entries: 128 (order: 0, 4096 bytes)
Jan  1 08:00:16 kernel: PCI: no core
Jan  1 08:00:16 kernel: PCI: scanning bus 0
Jan  1 08:00:16 kernel: PCI: Fixing up bus 0
Jan  1 08:00:16 kernel: PCIE1 link=1
Jan  1 08:00:16 kernel: PCIE1 switching to GEN2
Jan  1 08:00:16 kernel: PCI: bus0: Fast back to back transfers disabled
Jan  1 08:00:16 kernel: PCI: Fixing up bus 1
Jan  1 08:00:16 kernel: PCI: bus1: Fast back to back transfers disabled
Jan  1 08:00:16 kernel: pci 0001:00:00.0: BAR 8: assigned [mem 0x08000000-0x080fffff]
Jan  1 08:00:16 kernel: pci 0001:01:00.0: BAR 0: assigned [mem 0x08000000-0x08007fff 64bit]
Jan  1 08:00:16 kernel: pci 0001:01:00.0: BAR 0: set to [mem 0x08000000-0x08007fff 64bit] (PCI address [0x8000000-0x8007fff]
Jan  1 08:00:16 kernel: pci 0001:00:00.0: PCI bridge to [bus 01-01]
Jan  1 08:00:16 kernel: pci 0001:00:00.0:  bridge window [io  disabled]
Jan  1 08:00:16 kernel: pci 0001:00:00.0:  bridge window [mem 0x08000000-0x080fffff]
Jan  1 08:00:16 kernel: pci 0001:00:00.0:  bridge window [mem pref disabled]
Jan  1 08:00:16 kernel: PCIE2 link=1
Jan  1 08:00:16 kernel: PCIE2 switching to GEN2
Jan  1 08:00:16 kernel: PCI: Fixing up bus 2
Jan  1 08:00:16 kernel: PCI: bus2: Fast back to back transfers disabled
Jan  1 08:00:16 kernel: pci 0002:00:00.0: BAR 8: assigned [mem 0x40000000-0x400fffff]
Jan  1 08:00:16 kernel: pci 0002:02:00.0: BAR 0: assigned [mem 0x40000000-0x40007fff 64bit]
Jan  1 08:00:16 kernel: pci 0002:02:00.0: BAR 0: set to [mem 0x40000000-0x40007fff 64bit] (PCI address [0x40000000-0x40007fff]
Jan  1 08:00:16 kernel: pci 0002:00:00.0: PCI bridge to [bus 02-02]
Jan  1 08:00:16 kernel: pci 0002:00:00.0:  bridge window [io  disabled]
Jan  1 08:00:16 kernel: pci 0002:00:00.0:  bridge window [mem 0x40000000-0x400fffff]
Jan  1 08:00:16 kernel: pci 0002:00:00.0:  bridge window [mem pref disabled]
Jan  1 08:00:16 kernel: PCIE3 link=0
Jan  1 08:00:16 kernel: VFS: Disk quotas dquot_6.5.2
Jan  1 08:00:16 kernel: Dquot-cache hash Table entries: 1024 (order 0, 4096 bytes)
Jan  1 08:00:16 kernel: squashfs: version 4.0 (2009/01/31) Phillip Lougher
Jan  1 08:00:16 kernel: fuse init (API version 7.15)
Jan  1 08:00:16 kernel: msgmni has been set to 499
Jan  1 08:00:16 kernel: io scheduler noop registered (default)
Jan  1 08:00:16 kernel: io scheduler deadline registered
Jan  1 08:00:16 kernel: io scheduler cfq registered
Jan  1 08:00:16 kernel: Serial: 8250/16550 driver, 2 ports, IRQ sharing disabled
Jan  1 08:00:16 kernel: serial8250.0: ttyS0 at MMIO 0x18000300 (irq = 117) is a 16550
Jan  1 08:00:16 kernel: console [ttyS0] enabled, bootconsole disabled
Jan  1 08:00:16 kernel: serial8250.0: ttyS1 at MMIO 0x18000400 (irq = 117) is a 16550
Jan  1 08:00:16 kernel: brd: module loaded
Jan  1 08:00:16 kernel: loop: module loaded
Jan  1 08:00:17 kernel: pflash: found no supported devices
Jan  1 08:00:17 kernel: bcmsflash: found no supported devices
Jan  1 08:00:17 kernel: Boot partition size = 524288(0x80000)
Jan  1 08:00:17 kernel: lookup_nflash_rootfs_offset: offset = 0x200000
Jan  1 08:00:17 kernel: nflash: squash filesystem with lzma found at block 28
Jan  1 08:00:17 kernel: Creating 4 MTD partitions on "nflash":
Jan  1 08:00:17 kernel: 0x000000000000-0x000000080000 : "boot"
Jan  1 08:00:17 kernel: 0x000000080000-0x000000200000 : "nvram"
Jan  1 08:00:17 kernel: 0x000000200000-0x000004000000 : "linux"
Jan  1 08:00:17 kernel: 0x00000039a9c4-0x000004000000 : "rootfs"
Jan  1 08:00:17 kernel: PPP generic driver version 2.4.2
Jan  1 08:00:17 kernel: PPP MPPE Compression module registered
Jan  1 08:00:17 kernel: NET: Registered protocol family 24
Jan  1 08:00:17 kernel: PPTP driver version 0.8.5
Jan  1 08:00:17 kernel: u32 classifier
Jan  1 08:00:17 kernel:  Actions configured
Jan  1 08:00:17 kernel: Netfilter messages via NETLINK v0.30.
Jan  1 08:00:17 kernel: nf_conntrack version 0.5.0 (3992 buckets, 15968 max)
Jan  1 08:00:17 kernel: xt_time: kernel timezone is -0000
Jan  1 08:00:17 kernel: ip_Tables: (C) 2000-2006 Netfilter Core Team
Jan  1 08:00:17 kernel: TCP cubic registered
Jan  1 08:00:17 kernel: NET: Registered protocol family 10
Jan  1 08:00:17 kernel: ip6_Tables: (C) 2000-2006 Netfilter Core Team
Jan  1 08:00:17 kernel: NET: Registered protocol family 17
Jan  1 08:00:17 kernel: L2TP core driver, V2.0
Jan  1 08:00:17 kernel: PPPoL2TP kernel driver, V2.0
Jan  1 08:00:17 kernel: 802.1Q VLAN Support v1.8 Ben Greear <greearb@candelatech.com>
Jan  1 08:00:17 kernel: All bugs added by David S. Miller <davem@redhat.com>
Jan  1 08:00:17 kernel: Registering the dns_resolver key type
Jan  1 08:00:17 kernel: Northstar brcmnand NAND Flash Controller driver, Version 0.1 (c) Broadcom Inc. 2012
Jan  1 08:00:17 kernel: NAND device: Manufacturer ID: 0x01, Chip ID: 0xf1 (AMD NAND 128MiB 3,3V 8-bit)
Jan  1 08:00:17 kernel: Spare area=64 eccbytes 56, ecc bytes located at:
Jan  1 08:00:17 kernel:  2 3 4 5 6 7 8 9 10 11 12 13 14 15 18 19 20 21 22 23 24 25 26 27 28 29 30 31 34 35 36 37 38 39 40 41 42 43 44 45 46 47 50 51 52 53 54 55 56 57 58 59 60 61 62 63
Jan  1 08:00:17 kernel: Available 7 bytes at (off,len):
Jan  1 08:00:17 kernel: (1,1) (16,2) (32,2) (48,2) (0,0) (0,0) (0,0) (0,0)
Jan  1 08:00:17 kernel: Scanning device for bad blocks
Jan  1 08:00:17 kernel: Options: NO_AUTOINCR,NO_READRDY,BBT_SCAN2NDPAGE,
Jan  1 08:00:17 kernel: Creating 2 MTD partitions on "brcmnand":
Jan  1 08:00:17 kernel: 0x000004000000-0x000007ec0000 : "brcmnand"
Jan  1 08:00:17 kernel: 0x000007ec0000-0x000008000000 : "asus"
Jan  1 08:00:17 kernel: VFS: Mounted root (squashfs filesystem) readonly on device 31:3.
Jan  1 08:00:17 kernel: devtmpfs: mounted
Jan  1 08:00:17 kernel: Freeing init memory: 212K
Jan  1 08:00:17 kernel: cfe_commit: do nothing
Jan  1 08:00:17 kernel: ctf: module license 'Proprietary' taints kernel.
Jan  1 08:00:17 kernel: Disabling lock debugging due to kernel taint
Jan  1 08:00:17 kernel: et_module_init: passivemode set to 0x0
Jan  1 08:00:17 kernel: et_module_init: txworkq set to 0x1
Jan  1 08:00:17 kernel: et_module_init: et_txq_thresh set to 0xce4
Jan  1 08:00:17 kernel: eth0: Broadcom BCM47XX 10/100/1000 Mbps Ethernet Controller 6.37.14.105 (r485445)
Jan  1 08:00:17 kernel: wl_module_init: passivemode set to 0x0
Jan  1 08:00:17 kernel: wl_module_init: txworkq set to 0x1
Jan  1 08:00:17 kernel: eth1: Broadcom BCM4360 802.11 Wireless Controller 6.37.14.105 (r485445)
Jan  1 08:00:17 kernel: eth2: Broadcom BCM4360 802.11 Wireless Controller 6.37.14.105 (r485445)
Jan  1 08:00:17 kernel: JFFS2 version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
Jan  1 08:00:17 kernel: Empty flash at 0x016fae4c ends at 0x016fb000
Jan  1 08:00:17 kernel: JFFS2 notice: (365) check_node_data: wrong data CRC in data node at 0x016fb044: read 0x296c84c9, calculated 0x7fe1c2b9.
Jan  1 08:00:17 kernel: device vlan1 entered promiscuous mode
Jan  1 08:00:17 kernel: device eth0 entered promiscuous mode
Jan  1 08:00:17 kernel: device eth1 entered promiscuous mode
Jan  1 08:00:17 kernel: device eth2 entered promiscuous mode
Jan  1 08:00:17 kernel: br0: topology change detected, propagating
Jan  1 08:00:17 kernel: br0: port 3(eth2) entering forwarding state
Jan  1 08:00:17 kernel: br0: port 2(eth1) entering forwarding state
Jan  1 08:00:17 kernel: br0: port 1(vlan1) entering forwarding state
Jan  1 08:00:18 stop_nat_rules: apply the redirect_rules!
Jan  1 08:00:18 WAN Connection: ISP's DHCP did not function properly.
Jan  1 08:00:23 dnsmasq[488]: started, version 2.73rc9 cachesize 1500
Jan  1 08:00:23 dnsmasq[488]: warning: interface ppp1* does not currently exist
Jan  1 08:00:23 dnsmasq[488]: asynchronous logging enabled, queue limit is 5 messages
Jan  1 08:00:23 dnsmasq-dhcp[488]: DHCP, IP range 192.168.1.20 -- 192.168.1.40, lease time 1d
Jan  1 08:00:23 dnsmasq[488]: read /etc/hosts - 5 addresses
Jan  1 08:00:23 dnsmasq[488]: read /etc/hosts.dnsmasq - 2 addresses
Jan  1 08:00:23 dnsmasq-dhcp[488]: read /etc/ethers - 2 addresses
Jan  1 08:00:23 RT-AC68U: start httpd
Jan  1 08:00:23 crond[496]: crond: crond (busybox 1.20.2) started, log level 8
Jan  1 08:00:23 kernel: gro enabled with interval 2
Jan  1 08:00:23 hour monitor: daemon is starting
Jan  1 08:00:23 hour monitor: daemon terminates
Jan  1 08:00:23 disk monitor: be idle
Jan  1 08:00:25 Samba Server: daemon is started
Jan  1 08:00:25 dnsmasq[488]: read /etc/hosts - 5 addresses
Jan  1 08:00:25 dnsmasq[488]: read /etc/hosts.dnsmasq - 2 addresses
Jan  1 08:00:25 dnsmasq-dhcp[488]: read /etc/ethers - 2 addresses
Jan  1 08:00:25 kernel: usbcore: registered new interface driver usbfs
Jan  1 08:00:25 syslog: module ledtrig-usbdev not found in modules.dep
Jan  1 08:00:25 syslog: module leds-usb not found in modules.dep
Jan  1 08:00:25 kernel: usbcore: registered new interface driver hub
Jan  1 08:00:25 kernel: usbcore: registered new device driver usb
Jan  1 08:00:25 kernel: SCSI subsystem initialized
Jan  1 08:00:25 rc_service: udhcpc 557:notify_rc start_firewall
Jan  1 08:00:25 dnsmasq[488]: using nameserver 203.80.96.33#53 for domain local
Jan  1 08:00:25 dnsmasq[488]: using nameserver 203.186.94.20#53 for domain local
Jan  1 08:00:25 dnsmasq[488]: using nameserver 203.186.94.22#53 for domain local
Jan  1 08:00:25 kernel: csw_retry 100
Jan  1 08:00:25 kernel: Initializing USB Mass Storage driver...
Jan  1 08:00:25 kernel: usbcore: registered new interface driver usb-storage
Jan  1 08:00:25 kernel: USB Mass Storage support registered.
Jan  1 08:00:26 wan: finish adding multi routes
Jan  1 08:00:26 rc_service: udhcpc 557:notify_rc stop_upnp
Jan  1 08:00:26 rc_service: waitting "start_firewall" via udhcpc ...
Jan  1 08:00:26 dnsmasq-dhcp[488]: DHCPDISCOVER(br0) 00:xx:xx:xx:xx:2a
Jan  1 08:00:26 dnsmasq-dhcp[488]: DHCPOFFER(br0) 192.168.1.10 00:xx:xx:xx:xx:2a
Jan  1 08:00:26 dnsmasq-dhcp[488]: DHCPREQUEST(br0) 192.168.1.10 00:xx:xx:xx:xx:2a
Jan  1 08:00:26 dnsmasq-dhcp[488]: DHCPACK(br0) 192.168.1.10 00:xx:xx:xx:xx:2a PC
Jan  1 08:00:26 kernel: Tuxera FAT 12/16/32 driver version 3014.7.30 [Flags: R/W MODULE].
Jan  1 08:00:26 kernel: Tuxera NTFS driver 3014.7.29 [Flags: R/W MODULE].
Jan  1 08:00:26 kernel: Tuxera HFS+ driver 3014.7.28
Jan  1 08:00:26 kernel: xhci_hcd 0000:00:0c.0: xHCI Host Controller
Jan  1 08:00:26 kernel: xhci_hcd 0000:00:0c.0: new USB bus registered, assigned bus number 1
Jan  1 08:00:26 kernel: xhci_hcd 0000:00:0c.0: irq 112, io mem 0x18023000
Jan  1 08:00:26 kernel: xhci_hcd 0000:00:0c.0: Failed to enable MSI-X
Jan  1 08:00:26 kernel: xhci_hcd 0000:00:0c.0: failed to allocate MSI entry
Jan  1 08:00:26 kernel: usb usb1: No SuperSpeed endpoint companion for config 1  interface 0 altsetting 0 ep 129: using minimum values
Jan  1 08:00:26 kernel: hub 1-0:1.0: USB hub found
Jan  1 08:00:26 kernel: hub 1-0:1.0: 1 port detected
Jan  1 08:00:26 kernel: [xhci-hub] usb2mode:[0]
Jan  1 08:00:26 kernel: ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
Jan  1 08:00:26 kernel: ehci_hcd 0000:00:0b.1: EHCI Host Controller
Jan  1 08:00:26 kernel: ehci_hcd 0000:00:0b.1: new USB bus registered, assigned bus number 2
Jan  1 08:00:27 kernel: ehci_hcd 0000:00:0b.1: irq 111, io mem 0x18021000
Jan  1 08:00:27 kernel: ehci_hcd 0000:00:0b.1: USB 0.0 started, EHCI 1.00
Jan  1 08:00:27 kernel: hub 2-0:1.0: USB hub found
Jan  1 08:00:27 kernel: hub 2-0:1.0: 2 ports detected
Jan  1 08:00:27 kernel: ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
Jan  1 08:00:27 kernel: ohci_hcd 0000:00:0b.0: OHCI Host Controller
Jan  1 08:00:27 kernel: ohci_hcd 0000:00:0b.0: new USB bus registered, assigned bus number 3
Jan  1 08:00:27 kernel: ohci_hcd 0000:00:0b.0: irq 111, io mem 0x18022000
Jan  1 08:00:27 kernel: hub 3-0:1.0: USB hub found
Jan  1 08:00:27 kernel: hub 3-0:1.0: 2 ports detected
Jan  1 08:00:27 kernel: usbcore: registered new interface driver usblp
Jan  1 08:00:27 kernel: usbcore: registered new interface driver asix
Jan  1 08:00:27 kernel: usbcore: registered new interface driver cdc_ether
Jan  1 08:00:27 kernel: usbcore: registered new interface driver rndis_host
Jan  1 08:00:27 kernel: cdc_ncm: 14-Mar-2012
Jan  1 08:00:27 kernel: usbcore: registered new interface driver cdc_ncm
Jan  1 08:00:27 kernel: usb 2-1: new high speed USB device using ehci_hcd and address 2
Jan  1 08:00:27 kernel: usbcore: registered new interface driver cdc_wdm
Jan  1 08:00:27 kernel: usbcore: registered new interface driver qmi_wwan
Jan  1 08:00:27 kernel: cdc_mbim: loaded
Jan  1 08:00:27 kernel: usbcore: registered new interface driver cdc_mbim
Jan  1 08:00:27 kernel: usb 2-1: device descriptor read/64, error -71
Jan  1 08:00:27 kernel: usb 2-1: new high speed USB device using ehci_hcd and address 3
Jan  1 08:00:28 WAN Connection: WAN was restored.
Jan  1 08:00:28 start_nat_rules: apply the nat_rules(/tmp/nat_rules)!
Jan  1 08:00:28 kernel: usb 2-1: device descriptor read/64, error -71
Jan  1 08:00:28 kernel: usb 2-1: new high speed USB device using ehci_hcd and address 4
Jan  1 08:00:28 start_nat_rules: apply the nat_rules(/tmp/nat_rules_eth0_eth0)!
Jan  1 08:00:28 kernel: usb 2-1: device not accepting address 4, error -71
Jan  1 08:00:29 kernel: usb 2-1: new high speed USB device using ehci_hcd and address 5
Jan  1 08:00:29 kernel: usb 2-1: device not accepting address 5, error -71
Jan  1 08:00:29 kernel: hub 2-0:1.0: unable to enumerate USB device on port 1
Jan  1 08:00:29 kernel: nf_conntrack_rtsp v0.6.21 loading
Jan  1 08:00:29 kernel: nf_nat_rtsp v0.6.21 loading
Jan  1 08:00:29 kernel: usb 3-1: new full speed USB device using ohci_hcd and address 2
Jan  1 08:00:29 kernel: usb 3-1: device descriptor read/64, error -62
Jan  1 08:00:30 kernel: usb 3-1: device descriptor read/64, error -62
Jan  1 08:00:30 kernel: usb 3-1: new full speed USB device using ohci_hcd and address 3
Jan  1 08:00:31 rc_service: udhcpc 557:notify_rc start_upnp
Jan  1 08:00:31 kernel: usb 3-1: new full speed USB device using ohci_hcd and address 4
Jan  1 08:00:31 miniupnpd[707]: could not open lease file: /var/lib/misc/upnp.leases
Jan  1 08:00:31 miniupnpd[707]: HTTP listening on port 53300
Jan  1 08:00:31 miniupnpd[707]: Listening for NAT-PMP/PCP traffic on port 5351
Jan  1 08:00:31 kernel: usb 3-1: device not accepting address 4, error -62
Jan  1 08:00:31 kernel: usb 3-1: new full speed USB device using ohci_hcd and address 5
Jan  1 08:00:32 kernel: usb 3-1: device not accepting address 5, error -62
Jan  1 08:00:32 kernel: hub 3-0:1.0: unable to enumerate USB device on port 1
Jan  1 08:00:32 ntp: start NTP update
Oct 22 19:40:12 rc_service: ntp 708:notify_rc restart_upnp
Oct 22 19:40:12 miniupnpd[707]: shutting down MiniUPnPd
Oct 22 19:40:12 miniupnpd[717]: could not open lease file: /var/lib/misc/upnp.leases
Oct 22 19:40:12 miniupnpd[717]: HTTP listening on port 60127
Oct 22 19:40:12 miniupnpd[717]: Listening for NAT-PMP/PCP traffic on port 5351
Oct 22 19:40:13 kernel: * Make sure sizeof(struct sw_struct)=160 is consistent
Oct 22 19:40:13 rc_service: ntp 708:notify_rc restart_diskmon
Oct 22 19:40:13 disk_monitor: Finish
Oct 22 19:40:13 disk monitor: be idle
Oct 22 19:40:13 dnsmasq-dhcp[488]: DHCPDISCOVER(br0) 3a:xx:xx:xx:xx:a0
Oct 22 19:40:13 dnsmasq-dhcp[488]: DHCPOFFER(br0) 192.168.1.84 3a:xx:xx:xx:xx:a0
Oct 22 19:40:13 kernel: IDPfw: TrendMicro forward module ver-1.0.28
Oct 22 19:40:13 kernel: IDPfw: Apply module param dev_wan=eth0
Oct 22 19:40:13 kernel: IDPfw: Apply module param sess_num=30000
Oct 22 19:40:13 kernel: IDPfw: Init chrdev /dev/idpfw with major 191
Oct 22 19:40:13 kernel: IDPfw: IDPfw is ready
Oct 22 19:40:13 kernel: sizeof forward param = 160
Oct 22 19:40:14 dnsmasq-dhcp[488]: DHCPREQUEST(br0) 192.168.1.84 3a:xx:xx:xx:xx:a0
Oct 22 19:40:14 dnsmasq-dhcp[488]: DHCPACK(br0) 192.168.1.84 3a:xx:xx:xx:xx:a0 gateway
Oct 22 19:40:15 rc_service: udhcpc 557:notify_rc start_firewall
Oct 22 19:40:15 dhcp client: bound 119.15.1.57 via 119.15.1.12 during 43200 seconds.
Oct 22 19:40:15 start_nat_rules: apply the nat_rules(/tmp/nat_rules_eth0_eth0)!
Oct 22 19:40:22 dnsmasq-dhcp[488]: DHCPREQUEST(br0) 192.168.1.11 3a:xx:xx:xx:xx:58
Oct 22 19:40:22 dnsmasq-dhcp[488]: DHCPACK(br0) 192.168.1.11 3a:xx:xx:xx:xx:58 Tab
Oct 22 19:40:41 crond[496]: time disparity of 424060 minutes detected
Oct 22 19:40:51 dnsmasq-dhcp[488]: DHCPREQUEST(br0) 192.168.1.82 5c:xx:xx:xx:xx:7b
Oct 22 19:40:51 dnsmasq-dhcp[488]: DHCPACK(br0) 192.168.1.82 5c:xx:xx:xx:xx:7b de-iPad
Oct 22 20:00:13 disk_monitor: Got SIGALRM...
Oct 22 20:06:12 dnsmasq-dhcp[488]: DHCPREQUEST(br0) 192.168.1.95 34:xx:xx:xx:xx:61
Oct 22 20:06:12 dnsmasq-dhcp[488]: DHCPACK(br0) 192.168.1.95 34:xx:xx:xx:xx:61 iPad
Oct 22 20:25:03 dnsmasq-dhcp[488]: DHCPREQUEST(br0) 192.168.1.95 34:xx:xx:xx:xx:61
Oct 22 20:25:03 dnsmasq-dhcp[488]: DHCPACK(br0) 192.168.1.95 34:xx:xx:xx:xx:61 iPad
Oct 22 20:34:55 dnsmasq-dhcp[488]: DHCPREQUEST(br0) 192.168.1.95 34:xx:xx:xx:xx:61
Oct 22 20:34:55 dnsmasq-dhcp[488]: DHCPACK(br0) 192.168.1.95 34:xx:xx:xx:xx:61 iPad
Oct 22 20:49:30 dnsmasq-dhcp[488]: DHCPREQUEST(br0) 192.168.1.95 34:xx:xx:xx:xx:61
Oct 22 20:49:30 dnsmasq-dhcp[488]: DHCPACK(br0) 192.168.1.95 34:xx:xx:xx:xx:61 iPad
Hello, I think we have the same problem. Mine stops working completely, no Wi-Fi, no LAN no nothing. Leds work OK but nothing else, I also need to reboot the router manually. My log looks like yours. I think --> http://pastebin.ca/3216708
Have you found the problem?
