I see this in the logs:
So we can see WAN connection had some issues, then I chkwan script restarted the WAN which could not get the pppd connection up. But later chkwan rebooted the router then it was able to get WAN IP.
Dec 15 20:57:22 WAN(0)_Connection: Fail to connect with some issues.
Dec 15 20:57:57 pppd[2577]: Serial link appears to be disconnected.
Dec 15 20:58:03 pppd[2577]: Connection terminated.
Dec 15 20:58:03 pppd[2577]: Modem hangup
Dec 15 20:58:04 (ChkWAN.sh): 5763 v1.17 Monitoring WAN connection using PING method to 206.80.253.250 check FAILED
Dec 15 20:58:07 (ChkWAN.sh): 5763 v1.17 Monitoring WAN connection using PING method to 209.197.128.2 check FAILED
Dec 15 20:58:10 (ChkWAN.sh): 5763 v1.17 Monitoring WAN connection using PING method to 209.197.128.5 check FAILED
Dec 15 20:58:13 (ChkWAN.sh): 5763 v1.17 Monitoring WAN connection using PING method to 9.9.9.9 check FAILED
Dec 15 20:58:16 (ChkWAN.sh): 5763 v1.17 Monitoring WAN connection using PING method to 1.1.1.1 check FAILED
Dec 15 20:58:26 (ChkWAN.sh): 5763 Monitoring pass 2 out of 3
Dec 15 20:58:29 (ChkWAN.sh): 5763 v1.17 Monitoring WAN connection using PING method to 206.80.253.250 check FAILED
Dec 15 20:58:32 (ChkWAN.sh): 5763 v1.17 Monitoring WAN connection using PING method to 209.197.128.2 check FAILED
Dec 15 20:58:35 (ChkWAN.sh): 5763 v1.17 Monitoring WAN connection using PING method to 209.197.128.5 check FAILED
Dec 15 20:58:38 (ChkWAN.sh): 5763 v1.17 Monitoring WAN connection using PING method to 9.9.9.9 check FAILED
Dec 15 20:58:41 (ChkWAN.sh): 5763 v1.17 Monitoring WAN connection using PING method to 1.1.1.1 check FAILED
Dec 15 20:58:48 pppd[2577]: Timeout waiting for PADO packets
Dec 15 20:58:51 (ChkWAN.sh): 5763 Monitoring pass 3 out of 3
Dec 15 20:58:54 (ChkWAN.sh): 5763 v1.17 Monitoring WAN connection using PING method to 206.80.253.250 check FAILED
Dec 15 20:58:58 (ChkWAN.sh): 5763 v1.17 Monitoring WAN connection using PING method to 209.197.128.2 check FAILED
Dec 15 20:59:01 (ChkWAN.sh): 5763 v1.17 Monitoring WAN connection using PING method to 209.197.128.5 check FAILED
Dec 15 20:59:04 (ChkWAN.sh): 5763 v1.17 Monitoring WAN connection using PING method to 9.9.9.9 check FAILED
Dec 15 20:59:07 (ChkWAN.sh): 5763 v1.17 Monitoring WAN connection using PING method to 1.1.1.1 check FAILED
Dec 15 20:59:07 (ChkWAN.sh): 5763 Renewing DHCP and restarting WAN (Action=WANONLY)
Dec 15 20:59:17 rc_service: service 6962:notify_rc restart_wan
Dec 15 20:59:17 custom_script: Running /jffs/scripts/wan-event (args: 0 stopping)
Dec 15 20:59:17 pppd[2577]: Unable to complete PPPoE Discovery
Dec 15 20:59:17 custom_script: Running /jffs/scripts/wan-event (args: 0 stopped)
Dec 15 20:59:17 custom_script: Running /jffs/scripts/wan-event (args: 1 stopping)
Dec 15 20:59:17 custom_script: Running /jffs/scripts/wan-event (args: 1 stopped)
Dec 15 20:59:17 custom_script: Running /jffs/scripts/wan-event (args: 0 init)
Dec 15 20:59:17 custom_script: Running /jffs/scripts/wan-event (args: 0 connecting)
Dec 15 20:59:17 pppd[7107]: pppd 2.4.7 started by admin, uid 0
Dec 15 20:59:17 (ChkWAN.sh): 7079 ChkWAN scheduled by cron
*/2 * * * * /jffs/scripts/ChkWAN.sh wan nowait #WAN_Check#
Dec 15 20:59:17 (ChkWAN.sh): 7079 v1.17 WAN connection status monitoring will begin in 10 seconds.....
Dec 15 20:59:28 (ChkWAN.sh): 7079 v1.17 Monitoring WAN connection using 3 target PING hosts (0.0.0.0 9.9.9.9 1.1.1.1) (Tries=3)
Dec 15 20:59:28 (ChkWAN.sh): 7079 Private LAN 0.0.0.0 will be skipped for WAN PING check!
Dec 15 20:59:31 (ChkWAN.sh): 7079 v1.17 Monitoring WAN connection using PING method to 9.9.9.9 check FAILED
Dec 15 20:59:34 (ChkWAN.sh): 7079 v1.17 Monitoring WAN connection using PING method to 1.1.1.1 check FAILED
Dec 15 20:59:36 services: apply rules error(19665)
Dec 15 20:59:37 zcip_client: configured 169.254.220.65
Dec 15 20:59:37 services: apply rules error(19707)
Dec 15 20:59:40 services: apply rules error(19707)
Dec 15 20:59:43 services: apply rules error(19707)
Dec 15 20:59:44 (ChkWAN.sh): 7079 Monitoring pass 2 out of 3
Dec 15 20:59:44 (ChkWAN.sh): 7079 Private LAN 0.0.0.0 will be skipped for WAN PING check!
Dec 15 20:59:47 services: apply rules error(19707)
Dec 15 20:59:47 (ChkWAN.sh): 7079 v1.17 Monitoring WAN connection using PING method to 9.9.9.9 check FAILED
Dec 15 20:59:49 services: apply rules error(19707)
Dec 15 20:59:50 (ChkWAN.sh): 7079 v1.17 Monitoring WAN connection using PING method to 1.1.1.1 check FAILED
Dec 15 20:59:52 pppd[7107]: Timeout waiting for PADO packets
Dec 15 20:59:53 services: apply rules error(19707)
Dec 15 20:59:55 services: apply rules error(19707)
Dec 15 20:59:58 services: apply rules error(19707)
Dec 15 21:00:00 (ChkWAN.sh): 7794 v1.17 Check WAN monitor ALREADY running...ABORTing
Dec 15 21:00:00 (ChkWAN.sh): 7079 Monitoring pass 3 out of 3
Dec 15 21:00:00 (ChkWAN.sh): 7079 Private LAN 0.0.0.0 will be skipped for WAN PING check!
Dec 15 21:00:01 services: apply rules error(19707)
Dec 15 21:00:03 (ChkWAN.sh): 7079 v1.17 Monitoring WAN connection using PING method to 9.9.9.9 check FAILED
Dec 15 21:00:04 services: apply rules error(19707)
Dec 15 21:00:07 (ChkWAN.sh): 7079 v1.17 Monitoring WAN connection using PING method to 1.1.1.1 check FAILED
Dec 15 21:00:07 (ChkWAN.sh): 7079 Rebooting..... (Action=REBOOT)
May 5 01:05:12 haveged: haveged starting up
May 5 01:05:13 rc_service: service 2267:notify_rc restart_firewall
May 5 01:05:15 WAN(0)_Connection: WAN(0) link down.
May 5 01:05:21 openvpn-routing: Initializing killswitch
May 5 01:05:22 httpd: Succeed to init SSL certificate...8443
May 5 01:05:22 disk_monitor: be idle
May 5 01:05:22 hour_monitor: daemon is starting
May 5 01:05:22 avahi-daemon[2363]: Alias name "RT-AX86U_Pro" successfully established.
May 5 01:05:22 Samba_Server: daemon is started
May 5 01:05:25 custom_script: Running /jffs/scripts/wan-event (args: 0 init)
May 5 01:05:25 custom_script: Running /jffs/scripts/wan-event (args: 0 connecting)
May 5 01:05:25 pppd[2603]: pppd 2.4.7 started by admin, uid 0
May 5 01:05:25 (ChkWAN.sh): 2564 ChkWAN scheduled by cron
May 5 01:05:25 (ChkWAN.sh): 2564 v1.17 WAN connection status monitoring will begin in 10 seconds.....
May 5 01:05:26 : fwver: 3.0.0.4_388.8_4 (sn:S7IG5Q20XXXXXXX /ha:XX:XX:XX:XX:XX:XX )
May 5 01:05:26 rc_service: cfg_server 2517:notify_rc update_nbr
May 5 01:05:26 rc_service: waitting "restart_firewall" via ...
May 5 01:05:32 BONDING: option disabled
May 5 01:05:32 roamast: ROAMING Start...
May 5 01:05:33 WAN(0)_Connection: Fail to connect with some issues.
May 5 01:05:36 (ChkWAN.sh): 2564 v1.17 Monitoring WAN connection using 3 target PING hosts (0.0.0.0 9.9.9.9 1.1.1.1) (Tries=3)
May 5 01:05:36 (ChkWAN.sh): 2564 Private LAN 0.0.0.0 will be skipped for WAN PING check!
May 5 01:05:39 (ChkWAN.sh): 2564 v1.17 Monitoring WAN connection using PING method to 9.9.9.9 check FAILED
May 5 01:05:40 pppd[2603]: Connected to XX:XX:XX:XX:XX:XX via interface vlan40
May 5 01:05:40 pppd[2603]: Connect: ppp0 <--> vlan40
May 5 01:05:40 pppd[2603]: PAP authentication succeeded
May 5 01:05:40 pppd[2603]: peer from calling number XX:XX:XX:XX:XX:XX authorized
May 5 01:05:40 pppd[2603]: local IP address 17X.2X6.X4.X2
May 5 01:05:40 pppd[2603]: remote IP address 2XX.X0.2XX.XX9
May 5 01:05:40 pppd[2603]: primary DNS address 2XX.1XX.128.2
May 5 01:05:40 pppd[2603]: secondary DNS address 2XX.1XX.128.5
May 5 01:05:42 ntpd: Started ntpd
May 5 01:05:42 WAN(0)_Connection: WAN was restored.
Dec 15 21:01:33 ntpd: Initial clock set
Dec 15 21:01:33 rc_service: ntpd_synced 3255:notify_rc restart_diskmon
Dec 15 21:01:33 disk_monitor: Finish
