RBR50 converted to RBS50 "kills" the network after some time
Thomasx
Hi
I have an RBR50v2 router and satellite, and got an RBR50 router and satellite second hand to extend my system. The RBS50 is working fine with the v2 setup, and the RBR50 I converted to an RBS50 as explained in various web-pages. It connects and runs fine for a few hours or a day or so, but then it "kills" the network and the RBR50v2 router starts to disconnect from the the internet and reconnect all the time.
I am thinking it might be that the converted RBS50 starts to think it's an RBR50 after all, or something like that, and there occurs som kind of clash between the two.
Anyone else experienced similar problems?
Any ideas on what might be the case, how to do fault finding and or how to fix it?
As long as I keep the converted RBS50 turned off the system works fine.
