I've got an Orbi RBR50v2 that was flashed to voxel RBR50, but then I flashed it to voxel RBS50 (with changing the headers, via this method:
Since then my orbi is full white and when I connect to the interface, I just get a "404 Not Found".
I cannot upload firmware via TFTP because it doesn't get in the mode to accept firmware (no amber blinking led, goes directly to green and eventually the ip goes up).
I've tried to hold the reset button and then starting the router etc, but I can't seem to get into the firmware update mode
I do however can connect to the machine via SSH.
Is there a way to flash the firmware via SSH? or can I maybe try to enable the webui so it doesn't say not found?
Thank you!
Thank you!
