Thanks, but not interested in embedded software...
Looking for 3rd-party hw so can build the same thing (or similar) as the XG-7100.
I may yet go with everything I settled on
here (last updated Sep 24 2016).
But just wondering if anyone can help with my
post above...
Possible to put something together that's very similar to the XG-7100 yet;
Just as I did for the SG-8860 in my first link above?
Thanks again.
*UPDATE*
Cool, looks like SM does indeed offer 2* C3000 series bare-bones
1U units already!
http://www.supermicro.com/products/system/1U/5019/SYS-5019A-12TN4.cfm
http://www.supermicro.com/products/system/1U/5019/SYS-5019A-FTN4.cfm
Ofc, they're likely to be
quite different to what Netgate/ADI design & manufacture.
Thus, pfSense won't be QA like it will if I buy a Netgate unit, but,
close enough to whip into rock-solid reliability you reckon?
Problem is finding out how to bloody get it here...
What's the bet it doesn't ship to Oz from Amazon.com,
& local availability is slim to non-existent?!
But maybe Alibaba or similar do ship it? I'll check that later.
If it works out to be heaps more, then I may stick with the DIY C7258 build I was about to go with way back when!
If the cost of the DIY C7258 build or this DIY C3xxx build aren't far off from the XG-7100, then I may still get it.
Yet to run all of the numbers....
