cplay
The script only works with adaptive QoS.
Ah crap, was hoping to find a custom script for bandwidth limiting on specific devices.
Know of any scripts bouncing around?
I am also curious if individual device throttling is possible with thisAh crap, was hoping to find a custom script for bandwidth limiting on specific devices.
For me the AppDB portion didn't work and was the last thing @FreshJR was looking into.I was setting up router after reset, and questiona came to me:
-what's the difference between AppDB and Rule, only that rule is more specific than just QoS mark?
-I can only setup 3 rules and 3 appdb, or is it possible to setup more?
I'm currently using Rules, and was wondering to use a couple more than just the 3 showed
Show us the rules you tweaked at the top of the page so we can verify them.I'm wondering if anyone is able to help me with my Usenet traffic which is being classed into NNTP category?
I can see it coming in on Port 119 and I have the default rule which is Port 119 and 563 to be classified as "File Downloads" but when I monitor my traffic live my Usenet is getting marked as NNTP and absolutely choking my entire network.
This is a grab of my Usenet traffic and sorry in advance I am brand new to QoS and networking, I've done a fair bit of Googling and I have since IPv6 can be a cause, no idea how to work out if I'm using that though.
Looks good for the most part. Change the protocol to "Both", apply, and wait 5 mins to see if it starts showing as it should.Ok, they are all default except the bottom one which I added to make my PC considered a gaming device (yes this is the device I'm having issues on). Also the default rules are greyed out and I can't edit them, is that normal?
Change the protocol for the custom gaming rule to "Both". See below...each one of mine has Protocol filled out. Yours is blank.Ok thanks, again just to highlight I am not able to edit any of the original rules and I can't even change the protocol to apply to "Both" for the 119 and 563 rule. I've had to create a new rule which is essentially a duplicate of the existing default rule and configure that to both so it looks like what I've attached. This seems doesn't seem like correct behaviour can anyone else confirm if their default rules are locked?
Update: Ok so adding that second rule worked and it's now being classed as File Transfer so thank you! Now I am worried these greyed out default rules aren't being applied at all...![]()
Ah I'm with you thanks!Change the protocol for the custom gaming rule to "Both". See below...each one of mine has Protocol filled out. Yours is blank.
Also the "default" rule and yours aren't the same. The default is set to only tag TCP 119, 563 to File downloads, whereas yours is set for "Both: (TCP AND UDP) for 119, 563 to File Downloads. You can edit those default rules but you'd have to do it directly and not through the webpage.
@Meulsie if you have a screenshot already, delete the greyed out ones and create them properly as @QuikSilver suggests.
@QuikSilver, are you able to answer the question directed to me?
Sorry, I don't use this section of the router often, if ever.![]()
4) In what order do custom rules take precedence?
Rule on top of this list override rules towards bottom of this list
Iptable -- 4th position
Iptable -- 3rd position
Iptable -- 2nd position
Iptable -- 1rst position
Iptable hardcoded
Appdb -- 4th position
Appdb -- 3rd position
Appdb -- 2nd position
Appdb -- 1rst position
Appdb hardcoded
See my last sentence regarding the custom rules.Ah I'm with you thanks!
Gotcha, and I understood that the difference in the rule was the default is marked as TCP traffic whereas my custom one was marked as both. What was confusing me is the Usenet traffic coming in was marked as "TCP" so the default rule should have been applying regardless.
Cheers mate, I don't see any delete button though for the default rules. If I recreate them all and essentially double up would that cause unnecessary load on the router by possibly performing the same rule twice?
Sure can!@QuikSilver, are you able to answer the question directed to me?
| Thread starter | Title | Forum | Replies | Date |
Happy New Year to our Asuswrt-Merlin Addon Community! RTRHTR v1.5 RELEASE CELEBRATION! | Asuswrt-Merlin AddOns | 36 | |
FlexQoS FlexQoS 1.5.3 - Flexible QoS Enhancement Script for Adaptive QoS | Asuswrt-Merlin AddOns | 119 |
We use essential cookies to make this site work, and optional cookies to enhance your experience.
