vnStat [Release] vnStat-on-Merlin - UI, CLI and email - data use and data limit monitoring - R1 and R2
I think I have resolved my issue with vnstat stopping unexpectedly. It coincides with a scheduled reboot, and at that time dn-vnstat starts but vnstat itself doesn't. I couldn't find out where in the starting sequence precisely it failed, but the S33 starting code is not necessary for me after the initial installation, I think, so I hard-coded the choice of jffs or usb storage location and removed the S32 tests. Now it starts on a reboot.
I seem to recall other instances where a lot of Sxx code created a race condition or some other starting issue. Not sure why, as other add-ons seems to run ok even with a lot; Scribe has a lot offloaded to another file that gets called, for example.
Is there a way to transfer the stats across to a newer model of router ? I have it currently stored in jffs.
Please advise thanks
Hey @elorimer I'm having a similar issue with the stats. I've checked and it appears dn-vnstat runs after reboot, but vnstat is "dead" based on running this command:
/opt/etc/init.d/S33vnstat check
After starting vnstat using this command:
/opt/etc/init.d/S33vnstat start
the stats are updating just fine.
Can you please post what you modified in /opt/etc/init.d/s33vnstat file?
Thanks.
Please see https://www.snbforums.com/goto/post?id=817919
Note: there is no guarantee that it will work, this is an unsupported hack. I have, however, successfully done so at least twice in a test environment.
Thanks.
Please also see: https://www.snbforums.com/goto/post?id=910373 and https://www.snbforums.com/goto/post?id=910422 (recent posts on this issue) and https://www.snbforums.com/goto/post?id=892704.
It would be helpful for you to add your configuration (router, firmware version, scripts) to your signature and describe your topology (setup).
@dev_null thanks! I've gone through those threads but no luck.
My setup:
Router: AXE16K
FW: 3004.388.7
Scripts: Skynet, Unbound, AdGuard, dn-vnstat, spdMerlin, scMerlin
For those reading this thread instead of the other, please see this: https://www.snbforums.com/goto/post?id=910841
I've created a script (also posted in post #3 on page 1 of this thread) that will check the status of the S33vnstat daemon and if there are other than isolated reports of the daemon crashing/not starting, I may add this check to the dn-vnstat script.
I acknowledge it's treating the symptom not the disease, and will continue to try to identify why the daemon stops in a small number of cases.
@Martinski has submitted changes to the git that have been merged. The changes (which should show as v 2.0.6 include:
  • Fixed error when loading the webGUI page on the latest 3006.102.1 F/W version.
  • Fixed the "missing scrollbar" issue when the webGUI page was loaded on the latest 3004.386.14 F/W version.
  • Fixes/improvements when reading & checking for configuration settings.
  • Removed/modified code related to "var $j = jQuery.noConflict();" which is now considered obsolete.
Many thanks to those that flagged the issue and particularly to @Martinski !
Note: I have no device that runs the .14 variant, so I cannot check the scroll bar issue. Please advise if this fix doesn't address the issue.
Using RT-AC68U with Merlin 386.14 here, and I just tested the update immediately..
"missing scrollbar" issue got fixed indeed, as I just mentioned in my bug report's latest post:
Both my AX-88 and AX-86Pro are failing to start vnstatd on a reboot, so I found a little time to look at the log. It looks like S33 is being called before ntp has synced, so the script exits (no wait loop), but somehow the rest of dn-vnstat is running. I've added the ntp wait loop from S61unbound to the beginning of the script, and now it seems to start on a reboot. Maybe the starting sequence in the newer Merlins (388.0 and 3006) is just faster. (I didn't try the script in post #3). But since I inhabit the only universe with this problem, probably not.
Both my AX-88 and AX-86Pro are failing to start vnstatd on a reboot, so I found a little time to look at the log. It looks like S33 is being called before ntp has synced, so the script exits (no wait loop), but somehow the rest of dn-vnstat is running...
Your description of the reboot problem WRT the vnstatd service sounds very similar to the one reported in the following thread:
About 2 weeks ago, I submitted a pull request to the "vnstat-on-merlin" repo on GitHub that addresses the reboot issues. Here is my post with details on how to download the modified script version that includes the fix:
FYI.
Sorry, didn't see the other thread. Yes, this fixes the problem on both routers.
I had thought the problem was in S33vnstat, which has an ntp check but an immediate exit. So early in the boot process the logger in S33 reports the exit is triggered. No wait loop, and later dn-vnstat starts successfully but not the vnstatd. A wait loop fixes the problem.
Until this pull is merged, the webui page reports the version as 2.06, and checking for upgrade notes an upgrade to 2.06 is available. AMTM reports the version as 2.07.
EDIT: Also, started fine when the power came back on in Portugal.
Good to know that the modified 2.0.7 version script is working well for you.
For other users to easily find and get the latest 2.0.7 version from this vnStat thread, here is the set of commands to download the 2.0.7 script from the current PR #33 (which, as of this writing, is not yet merged into the main branch) submitted to the "vnstat-on-merlin" GitHub repo:
Bash:
curl -LSs --retry 3 --retry-delay 5 --retry-connrefused \
  https://raw.githubusercontent.com/de-vnull/vnstat-on-merlin/dd6721f93e1b8a93c02b24a4e9c43c3ddb87e119/dn-vnstat.sh \
  -o /jffs/scripts/dn-vnstat && chmod 755 /jffs/scripts/dn-vnstat
And here are my current Release Notes for the 2.0.7 version (UPDATED: 2025-May-01):
  1. Fixes to make sure the vnstatd Entware service is started during the reboot sequence after NTP is synced.
  2. Fixed bug where changing the "Data Storage Location" from JFFS to USB (or vice-versa) using the WebGUI page leaves behind some duplicate files and directories. This bug doesn't happen when using the SSH CLI menu option to change the data storage location.
  3. Modified code so that every time the SSH CLI menu is run, it checks if the WebGUI page has already been mounted. If not found mounted, the script will run the code to remount the WebGUI.
  4. Improved code that creates (during installation) and removes (during uninstallation) the "AddOns" menu tab entry for the WebGUI to make sure it checks for and takes into account other add-ons that may have been installed before or were later installed after the initial installation.
  5. Added code to show the current database file size information on the SSH CLI menu.
  6. Added code to show the "JFFS Available" space information for the "Data Storage Location" option on the SSH CLI menu.
  7. Added code to check if sufficient JFFS storage space is available before moving database-related files/folders from USB location to JFFS partition. An error message is reported if not enough space is available, and the move request is aborted.
  8. Added code to check if the available JFFS storage space falls below 20% of total space or 10MB (whichever is lower) and report a warning when it does. A warning message is also shown on the SSH CLI menu.
  9. Modified code to set the corresponding priority level of log entries when calling the built-in logger utility.
  10. Added "export PATH" statement to give the built-in binaries higher priority than the equivalent Entware binaries.
  11. Miscellaneous code improvements & fine-tuning.
FYI
On GT-AX6000 it keeps saying:
"eth0: No data. Timestamp of last update is same 2025-05-01 08:30:55 as of database creation."
Do you know if the interface name is different on this router?
adminGT-AX6000/tmp/home/root cat /proc/net/dev | grep eth0
  eth0: 42760230843 32869719    0    0    0     0          0      2267 3248361434 6996123
   0    0    0     0       0          0
eth0 have traffic. However, vnstat doesn't recognize it.
Any ideas? 💡
This message comes from the "vnstat" Entware binary, and I'm not familiar at all with its inner workings to begin to know where or what the problem is, or how to troubleshoot the problem.
   0    0    0     0       0          0
Any ideas? 💡
For now what I can suggest is to double-check that the required files are in place and where they're expected. To that end, run the following set of commands (including thee enclosing curly braces) in an SSH terminal window and post the generated output file (e.g. $HOME/VNStat_DEBUG_*.log):
Bash:
   date +'%c'
   echo "$(nvram get firmver).$(nvram get buildno).$(nvram get extendno)"
   nvram show 2>/dev/null | grep -E 'wan[0-1]_(primary=1|ifname=e.*)'
   grep "readonly SCRIPT_VERSION=" /jffs/scripts/dn-vnstat
   for dirPath in  /opt/share  /jffs/addons
   do
       if [ -d "${dirPath}/dn-vnstat.d" ]
       then
           echo "========================================"
           printf "${dirPath}/\n---------------\n"
           ls -1lF "${dirPath}/dn-vnstat.d"
           if [ -f "${dirPath}/dn-vnstat.d/config" ]
           then
               printf "\nCONFIG:\n-------\n"
               ls -1l "${dirPath}/dn-vnstat.d/config"
               echo "----------------------"
               cat "${dirPath}/dn-vnstat.d/config"
           fi
       fi
   done
   top -bn1 | head -n4
   top -bn1 | grep 'vnstat' | grep -v 'grep'
} > "$HOME/VNStat_DEBUG_$(date +'%Y%m%d_%H%M%S').log"
Another suggestion would be, as a last resort, to completely uninstall the add-on and then reinstall it using the latest 2.0.7 shell script version with the following commands:
Bash:
  -o /jffs/scripts/dn-vnstat && chmod 755 /jffs/scripts/dn-vnstat && /jffs/scripts/dn-vnstat install
HTH.
Bash:
   date +'%c'
   do
       then
           then
           fi
       fi
   done
   top -bn1 | head -n4
Bash:
  https://raw.githubusercontent.com/de-vnull/vnstat-on-merlin/3a5c1ae073a3a5f0ecd5bddfcb85eea420eae267/dn-vnstat.sh \
HTH.
Thanks for you help!
Fri 02 May 2025 10:06:56 AM IST
3.0.0.6.102.4.beta2
wan0_ifname=eth0
wan0_primary=1
readonly SCRIPT_VERSION="v2.0.7"
/opt/share/
/jffs/addons/
-rw-r--r--    1       113 May  2 10:06 config
drwxrwxrwx    2      1248 May  2 10:06 csv/
drwxrwxrwx    2       880 May  2 10:06 images/
-rw-rw-rw-    1     55964 May  1 08:40 vnstat-ui.asp
-rw-rw-rw-    1      4991 May  2 10:06 vnstat.conf
-rw-rw-rw-    1      4996 May  1 08:30 vnstat.conf.default
-rw-rw-rw-    1       421 May  2 10:06 vnstat.txt
CONFIG:
-rw-r--r--    1       113 May  2 10:06 /jffs/addons/dn-vnstat.d/config
DAILYEMAIL=html
USAGEEMAIL=false
DATAALLOWANCE=0.00
ALLOWANCEUNIT=G
STORAGELOCATION=jffs
OUTPUTTIMEMODE=non-unix
Mem: 791688K used, 226820K free, 5344K shrd, 23676K buff, 198928K cached
CPU:  4.7% usr  4.7% sys  0.0% nic 90.4% idle  0.0% io  0.0% irq  0.0% sirq
Load average: 0.47 0.35 0.28 2/221 27361
  PID  PPID USER     STAT   VSZ %VSZ CPU %CPU COMMAND
27335     1 admin    S     5160  0.5   2  0.0 vnstatd -d --noadd --config /jffs/addons/dn-vnstat.d/vnstat.conf
Bash:
FYI
I've merged these changes in anticipation of Martinski forking and migration to AMTM-OSR GitHub repo.
Thanks everyone for your patience and support. It's been a great run, but life has taken me in a different direction, one that doesn't give much free time for tinkering with my router.
Wishing everyone the best!
Dev_null
@RMerlin (or other mod) should we lock this thread and pick up in OSR?
Dev_null
Thanks @dev_null
I've forked vnstat into OSR just now, we can handle the migration from here.
We may submit one final PR to your repo if that's okay with you (just to point users to OSR when we are ready.)
I did notice you have a number other branches outside of "main"; I just want to validate none of these additional branches are production ready or currently being worked on?
Most recent would be: de-vnull-icloud-patch-1 from last year
