Replace failing 60m catV cable with d'link DIR655, belkin... Ap/bridge
The Merlin supported drives lists RT-AC56U. Amazon has a cheap deal on RT-N56U which seems to be without DSL/modem stuff which I do not envisage ever needing. How can I know if Merlin will run on it OK same as the AC(56U)?
Looks like that unit might do all I need at a lots less $$/££
https://www.amazon.co.uk/dp/B004TPWRSK/?tag=smallncom-21
I assume all the nbg modes & channels radio stuff is the same? Will the range be better than DIR655?
The RT-N56U and the RT-AC56U are all past their expiry date. No RMerlin support for those devices anymore.
There is a fork of the RMerlin firmware by john9527 that may be a possible solution for the once great little RT-AC56U, but I cannot recommend them anymore. They were once underdogs that punched above their class, but today I cannot say (with john9527's firmware) how they would compare anymore.
The RT-N56U never had a good range or speed. But it was very inexpensive. :)
No coax, the fibre runs to optical splitter 1 way to internet box, other way to runs to a v+ box that pulls its own video data streams for 3 or 4 simultaneous viewing/recording HD channels. All close to the side shed I mentioned where I'd site my wifi router (if I give up on catV down the garden path).
Hope that paints a clear enough picture (I know it so it makes sense to me, but that does not mean it IS clear!)
Not clear to me (sorry). :)
Don't let your WiFi be in another building. Run a cable to bring it inside your home.
Better yet, bring the ISP back to bring the fibre the last few feet to your home too. ;)
