oostertoaster
Hi All,
I'm starting to look for a replacement for my E3000 router, and was hoping for some advice.
First, an explanation of why I'm looking to replace it: I haven't really placed a great deal of emphasis on wireless performance in the past (almost all of my clients are wired with the exception of cell-phones and my wife's ipad). However my wife got a chromecast for christmas, and the performance leaves something to be desired. After a bit of investigating it became apparent that the wireless signal strength near my TV isn't very strong (-85 dBm as reported by wifi analyzer). I'm fairly certain this is leading to some terrible playback performance, mainly constant buffering.
Given the E3000's internal antennas, I was wondering if you think a router with decent external antennas might improve my wireless range? I had my eye on either the RT-AC66U or the RT-AC68U from Asus. Is the main difference between these routers the processor used (ARM vs MIPS)?
I should note that since the chromecast doesn't support 5GHz I'm mainly concerned with 2.4GHz at this point.
I'd love to hear what you guys think. Thanks in advance!
