i currently have thr RT-AX88U as main router with RT-AC86U as aimesh node(5Ghz backhaul)
it works but is not perfect(disconnects sometimes)
what would be the best/most stable choice if i replace the RT-AC86U
RT-AX88U same model with AX speed
RT-AX86U different model with AX speed
RT-AX86U pro different model with ax speed(seems to be cheaper than the RT-AX86U non pro version)
i need the 8 ports in the main router so replacing that with the pro version is a no go
