REQ - need some OpenSSL numbers/info
Raspberry Pi 3 OpenELEC (official) Version: 6.0.3
ARMv7 Processor rev 4 (v7l) 4core, Hardware: BCM2709, Revision: a02082
Pi3 - Ubuntu 16.04, haven't had much time to tune it, as it's running the SD card from my Pi2... and this is an armhf 32-bit build, so it really doesn't leverage into the ARM8 instruction set improvements.
Bodes well for ARM8's, IMHO... pi3 is a Quad A53 @ 1.2GHz
[B]sfx@raspy[/B]:[B]~[/B]$ openssl speed -evp aes-128-cbc
Doing aes-128-cbc for 3s on 16 size blocks: 7285042 aes-128-cbc's in 3.00s
Doing aes-128-cbc for 3s on 64 size blocks: 2219424 aes-128-cbc's in 3.00s
Doing aes-128-cbc for 3s on 256 size blocks: 590834 aes-128-cbc's in 3.00s
Doing aes-128-cbc for 3s on 1024 size blocks: 149994 aes-128-cbc's in 3.00s
Doing aes-128-cbc for 3s on 8192 size blocks: 18873 aes-128-cbc's in 3.00s
OpenSSL 1.0.2g-fips  1 Mar 2016
built on: reproducible build, date unspecified
options:bn(64,32) rc4(ptr,char) des(idx,cisc,16,long) aes(partial) blowfish(ptr)
compiler: cc -I. -I.. -I../include  -fPIC -DOPENSSL_PIC -DOPENSSL_THREADS -D_REENTRANT -DDSO_DLFCN -DHAVE_DLFCN_H -DL_ENDIAN -g -O2 -fstack-protector-strong -Wformat -Werror=format-security -Wdate-time -D_FORTIFY_SOURCE=2 -Wl,-Bsymbolic-functions -Wl,-z,relro -Wa,--noexecstack -Wall -DOPENSSL_BN_ASM_MONT -DOPENSSL_BN_ASM_GF2m -DSHA1_ASM -DSHA256_ASM -DSHA512_ASM -DAES_ASM -DBSAES_ASM -DGHASH_ASM
The 'numbers' are in 1000s of bytes per second processed.
type             16 bytes     64 bytes    256 bytes   1024 bytes   8192 bytes
aes-128-cbc      38853.56k    47347.71k    50417.83k    51197.95k    51535.87k
If one were to look at progress over time... easy runs, nothing special...
MIPS24K - QCAtheros 9531 @ 650MHz... (OpenWRT 18.06.1)
blowfish cbc 10107.46k 10782.48k 10985.58k 11038.01k 11100.71k
aes-128 cbc 7922.63k 8736.76k 8987.15k 9004.97k 9077.40k
aes-256 cbc 6190.39k 6714.84k 6839.67k 6877.11k 6876.82k
ARMv6L - Broadcom BCM2835 @ 1.0GHz... (Raspbian Stretch)
type 16 bytes 64 bytes 256 bytes 1024 bytes 8192 bytes 16384 bytes
blowfish cbc 15878.10k 19067.01k 20086.37k 20337.68k 20463.28k 19977.37k
aes-128 cbc 19628.84k 22103.27k 22753.89k 22927.53k 22959.82k 22743.21k
aes-256 cbc 15562.67k 16931.26k 17445.18k 17446.40k 17545.93k 17361.49k
ARM Cortex-A53 - Allwinner H5 @ 1.0GHz... (Ubuntu Bionic)
blowfish cbc 33262.87k 37159.08k 38249.47k 38586.37k 38674.43k 38677.16k
aes-128 cbc 32963.74k 36085.89k 37155.41k 37432.32k 37508.44k 37481.13k
aes-256 cbc 26044.15k 27596.93k 28197.03k 28412.25k 28412.59k 28409.86k
