[Request] Change VLAN ID over Web UI
bayern1975
hello, is possible in future update add settings to change VLAN ID over Web UI? i have a lot`s of disconnectivity every day because internet (WAN) and IPTV-udpxy (LAN4) ports using a same VLAN ID. i tested all combinations in last three month`s and same VLAN ID cause a problem. I need to have VLAN 2 for WAN port and VLAN 1 for LAN4 port.....it is not possible to change something over Web UI and hope you will change in asus code something that i can configure over Web UI.....
I see your running Merlin firmware.
Did you mean to post this in the Merlin firmware forum?
You posted in the official firmware forum.
Merlin firmware forum is here: http://www.snbforums.com/forums/asuswrt-merlin.42/
Edit: If you were talking about adding something to Merlin firmware you may want to read this: http://www.snbforums.com/threads/state-of-the-project-august-2016.33995/
i post at merlin thread yet but he answered me that he will not touch VLAN code....so last hope is that asus stuff made something....
sent from Kodi 17 Krypton
I think Shibby Tomato will allow you to do what you want to with the VLAN ID's and he now has a version for the RT-AC3200.
I try it many times but never get working iptv-udpxy with tomato...my ISP is very specific because i need two cables one for internet and one for IPTV....
