restoring cstats and rstats
andresmorago
Hello
Sorry if this has been discussed before. I couldnt find anything.
I had to reset my router after upgrading to latest version. I got a copy of 2 gz statt files that i had configured to be stored on my usb drive. After restoring my router, is there a way i could kee using these stats files instead of starting from zero?
thanks
First, make sure you keep a copy of those files in a safe location so they don't accidentally get overwritten.
I haven't tried this, but would assume that if you setup the traffic monitoring options it will start looking for those files. You should see such messages in the syslog. Presumably you could now copy the original files to the appropriate directories and reboot to make them active?
Let us know how you get on.
I have not tried it either but I backup the following files in case I do:
/jffs/.sys/AiProtectionMonitor/AiProtectionMonitor.db
/jffs/.sys/WebHistory/WebHistory.db
/jffs/.sys/TrafficAnalyzer/TrafficAnalyzer.db
/jffs/.sys/nc/nt_center.db
/tmp/mnt/ent/traffic/tomato_rstats_0c9d9201f098.gz
Hi. I tried it and after enabling traffic monitoring and rebooting, cstats and rstats are created from scratch. I tried to replace them and after another reboot, files will be restarted from scratch again (file size will go back to 1kb instead of my backups files sizes)
Try this:
Log onto the router and
# killall rstats
# killall cstats
Then copy over the old files and
# sync
Now turn off the power to the router. Don't use the software reboot. Then turn the power back on.
Any change?
Try this:
# killall rstats
# killall cstats
# sync
Any change?
success!!
now i will wait to see it restored file is updated with new stats
thanks so much
