Restricting access to specific ports - Whitelist ?
OK - I'm still having issues.
This is what I've currently got setup
iptables -I FORWARD -p udp --dport 5060 -j DROP
iptables -I FORWARD -p udp --dport 5068 -j DROP
iptables -I FORWARD -p udp -s 61.243.142.120 --dport 5060 -j ACCEPT
iptables -I FORWARD -p udp -s 88.215.134.231 --dport 5060 -j ACCEPT
iptables -I FORWARD -p udp -m string --string sipgate --algo bm --dport 5060 -j ACCEPT
iptables -I FORWARD -p udp -m string --string sipgate --algo bm --dport 5068 -j ACCEPT
iptables -I FORWARD -p udp -m string --string voice --algo bm --dport 5068 -j ACCEPT
iptables -I FORWARD -p tcp --dport 5060 -j DROP
iptables -I FORWARD -p tcp --dport 5068 -j DROP
iptables -I FORWARD -p tcp -s 61.243.142.120 --dport 5060 -j ACCEPT
iptables -I FORWARD -p tcp -s 88.215.134.231 --dport 5060 -j ACCEPT
iptables -I FORWARD -p tcp -m string --string sipgate --algo bm --dport 5060 -j ACCEPT
iptables -I FORWARD -p tcp -m string --string sipgate --algo bm --dport 5068 -j ACCEPT
iptables -I FORWARD -p tcp -m string --string voice --algo bm --dport 5068 -j ACCEPT
I'm finding this is blocking ALL UDP/TCP for 5060 & 5068 including the entries specified to be allowed.
Why ?
If I remove the:
Then all my SIP trunks work, but I'm open to anything again..
Any ideas how to block everything on port 5060 & 5068 except the entries I've listed ?
Never mastered iptables, but isn't your problem that the 2 rules dropping traffic to 5060 and 5068 are at the top of the list, so those rules get actioned first; nothing addressed to 5060 or 5068 ever gets checked against any other rules because the the first 2 have already made the decision as to what happens? Don't the drop rules to those 2 ports need to come AFTER every other rule pertaining to those 2 ports?
This will tell you what's going on. Check the pkts & bytes counts to see that your rules are being matched. Chances are that your rules are not matching anything.
/usr/sbin/iptables -nvL --line-numbers
I've removed all the rules I added and then added two new ones:
iptables -A FORWARD -p udp --dport 5060 -j DROP
iptables -A FORWARD -p tcp --dport 5060 -j DROP
Making an external SIP Call still works even though 5060 is blocked.
/usr/sbin/iptables -nvL --line-numbers returns :
10       0     0 DROP       tcp  --  *      *       0.0.0.0/0            0.0.0.0/0            tcp dpt:5060
11       0     0 DROP       udp  --  *      *       0.0.0.0/0            0.0.0.0/0            udp dpt:5060
so it isn't matching at all.
Is this because I have port forwarding for 5060 set ?
Hi
I've been having another look at this and I'm not sure my iptables is correct.
This is what it currently shows:
Chain INPUT (policy ACCEPT)
target     prot opt source               destination
DROP       icmp --  anywhere             anywhere             icmp echo-request
DROP       all  --  anywhere             anywhere             state INVALID
ACCEPT     all  --  anywhere             anywhere             state RELATED,ESTABLISHED
ACCEPT     all  --  anywhere             anywhere             state NEW
ACCEPT     udp  --  anywhere             anywhere             udp spt:bootps dpt:bootpc
ACCEPT     tcp  --  anywhere             anywhere             tcp dpt:1723
ACCEPT     gre  --  anywhere             anywhere
Chain FORWARD (policy DROP)
ipttolan   all  --  anywhere             anywhere
iptfromlan  all  --  anywhere             anywhere
ACCEPT     all  --  anywhere             anywhere             ctstate DNAT
Chain OUTPUT (policy ACCEPT)
Chain FUPNP (0 references)
Chain PControls (0 references)
Chain iptfromlan (1 references)
RETURN     all  --  anywhere             anywhere            account: network/netmask: 192.165.10.0/255.255.255.0 name: lan
Chain ipttolan (1 references)
Chain logaccept (0 references)
LOG        all  --  anywhere             anywhere             state NEW LOG level warning tcp-sequence tcp-options ip-options prefix "ACCEPT "
Chain logdrop (0 references)
LOG        all  --  anywhere             anywhere             state NEW LOG level warning tcp-sequence tcp-options ip-options prefix "DROP "
I've just tried adding this rule and no errors were detected:
iptables -t nat -I VSERVER 3 -p udp -m udp -s 88.235.62.224 --dport 5060 -j DNAT --to 192.165.10.10
yet I can't see it in the iptables output at all.
Also I have several entries in the Virtual Server / Port Forwarding page, but they don't appear.
At the moment traffic is coming in and going out on 5060 to/from any address !
I've removed my nat-start script and rebooted the router, but it's still shows as above.
Any ideas ?
Quick update. The router log shows 'start_nat_rules: apply the nat_rules(/tmp/nat_rules_ppp0_eth0)!'
Looking at that file it contains :
*nat
:PREROUTING ACCEPT [0:0]
:POSTROUTING ACCEPT [0:0]
:OUTPUT ACCEPT [0:0]
:VSERVER - [0:0]
:LOCALSRV - [0:0]
:VUPNP - [0:0]
:DNSFILTER - [0:0]
:PCREDIRECT - [0:0]
-A PREROUTING -d xxx.xxx.xxx.xxx -j VSERVER
-A PREROUTING -d 169.254.234.57 -j VSERVER
-A VSERVER -p tcp -m tcp --dport 21 -j DNAT --to-destination 192.165.10.50:21
-A VSERVER -p tcp -m tcp --dport 2021 -j DNAT --to-destination 192.165.10.1:21
-A VSERVER -p tcp -m tcp --dport 9091 -j DNAT --to 192.165.10.30
-A VSERVER -p tcp -m tcp --dport 8050 -j DNAT --to 192.165.10.30
-A VSERVER -p tcp -m tcp --dport 8082 -j DNAT --to-destination 192.165.10.60:8082
-A VSERVER -p tcp -m tcp --dport 5068 -j DNAT --to-destination 192.165.10.13:5068
-A VSERVER -p udp -m udp --dport 5068 -j DNAT --to-destination 192.165.10.13:5068
-A VSERVER -p udp -m udp --dport 6900:7859 -j DNAT --to 192.165.10.13
-A VSERVER -p tcp -m tcp --dport 5000 -j DNAT --to 192.165.10.13
-A VSERVER -p udp -m udp --dport 6300:6699 -j DNAT --to 192.165.10.10
-A VSERVER -p tcp -m tcp --dport 5065 -j DNAT --to-destination 192.165.10.120:5065
-A VSERVER -j VUPNP
-A POSTROUTING  -o ppp0 ! -s xxx.xxx.xxx.xxx -j MASQUERADE
-A POSTROUTING  -o eth0 ! -s 169.254.234.57 -j MASQUERADE
-A POSTROUTING  -m mark --mark 0xb400 -j MASQUERADE
COMMIT
Why don't I see these IP table rules in the output ?
Thanks that shows the nat rules but not why it appears to fail to match them..
I'm happy to try any ideas.. Thanks
