escape75
I don’t know about the 9260, but I know the 8260 and 8265
have huge issues with the rt-ac1900p (probably same with the
rt-ac68u I imagine) when you connect using 2.4 ghz band.
I tried 2 different laptops with 2 different cards, and 2 different
routers (same model) and both had major connection issues.
It seems sometimes the default gateway goes unreachable,
and sometimes you can have a background download which
will be going fine, but any new website requests to some sites
will fail for 20 seconds, and then it will fix itself.
This is all while windows reports a perfect signal to the router.
I’ve reported to Intel and they are looking at this, on forums.
I've tried windows resets, reinstalls, many driver versions, all same ...
It’s also interesting same laptop works fine on 2.4 ghz with a rt-n66u
