MonkY
Well, i am sure it's not that well designed if i had to move my RT-N66U in a much cooler area, because of overheating. And i suppose you know the designed board had initially an active cooler, which was later removed/replaced by only aluminium heatsink (which i think it's not enough).There is nothing wrong with the amount of heat generated, the hardware was designed for this.
I believe you. But i also owned like 20 D-Link routers (and installed a few hundreds of them) and none of them was even close to half the heat N66U is generating.My former WRT320N was actually running hotter than this, leaving the wooden shelf on which it sat quite warm to the touch. My cablemodem also runs much warmer than my RT-AC66U.
Can you please just compare the temperature between RT-AC66U and RT-N66U? Maybe they have improved the thermal conductivity on the newer model. I'm about to sell my N66U (because of this issue - it gets at arround 48-50 degrees Celsius on outside, specially on the metal frame of the ports), and i am hoping the AC66U is much cooler.
Thanks in advance!
