/root is full what to do
fearz
Filesystem Size Used Available Use% Mounted on
/dev/root 36.8M 36.8M 0 100% /
devtmpfs 251.4M 0 251.4M 0% /dev
tmpfs 251.6M 2.0M 249.5M 1% /tmp
/dev/mtdblock4 64.0M 10.6M 53.4M 16% /jffs
/dev/root 36.8M 36.8M 0 100% /usr/sbin/tc
/dev/sdf1 1.8G 29.8M 1.6G 2% /tmp/mnt/TheMiniWay
How to expand it or free it?
root (/dev/root) is always "full" because it's in ROM. That's normal.
/root is a symlink to /tmp/home/root so that resides in RAM. Your output shows it is only 1% used.
If you needs extra space in your home directory (ie. not "/" as above, but rather the home dir for root - ie. the dir you get when logged in and enter "cd ~"), you could use a USB and mount over existing.
Add the following (be sure to customize USB name) to your post-mount script in /jffs/scripts.
if [ "$1" = "/mnt/YOUR_USB_NAME_HERE" ];then
    mount -o bind $1/newroot /home/root
fi
You need to create folder "newroot" on your USB or whatever you want to call it.
fi
