Laxarus
Hello,
I have setup a two-way OpenVPN server-client pair with my RT-AC5300 and synology NAS. They can ping and access each other with no problem remotely.
Current Setup
VPN Server:
LAN IP: 192.168.1.1
VPN IP: 10.16.0.1
VPN Client:
LAN IP: 192.168.10.40
VPN IP: 10.16.0.3
I can ping the ip address 192.168.10.40 with any client behind the router and there is no problem.
What I want to do is to change that and use an IP address in the local range like 192.168.1.40.
This way any client behind the host should be able to ping 192.168.1.40 and this should ping the remote device.
What would be the way to do that? Static Routes etc??
Current Setup
VPN Server:
LAN IP: 192.168.1.1
VPN IP: 10.16.0.1
VPN Client:
VPN IP: 10.16.0.3
