Why would you be using legacy protocols that are known to be security risks?
How Route ONLY SPECIFIC LAN IPs thru L2TP/PPTP VPN Client?
ip route xxxxxx
) and create rules to assign given client to that table (ip rule xxxx
). You would need to put those commands in a custom script and plug it somewhere.Personal choice if they think it's more compatible etc.Why would you be using legacy protocols that are known to be security risks?
I think you're (incorrectly) assuming that "security" is the concern. All the OP probably wants to do do is send streaming traffic out a different IP. In which case there's no risk of eves-dropping anyway.Why would you be using legacy protocols that are known to be security risks?
Don't know if this is still relevantThe OP asked a pretty specific question. For arguments sake, let's assume they're on 386.7_2. How does that help you answer their question?
I think what they meant to ask is if there's a VPN Director like tool or add-on that supports other protocols, and I'd like to know the answer too.
Welcome To SNBForums
