Where I live all the available ISP provide you with a pretty poor wifi router as your connection.
So I connect the WAN port on my own wifi router to one of the LAN ports on the ISP wifi router. I then connect the rest of my network devices to my own wifi router.
There are very few settings i can change with the access level i have to the ISP router, I have disabled the wifi and that's all.
I am wondering if there are any settings i should change in my own router with this set up? for example I can see NAT is enabled on the ISP router should i disable it on my own router?
My network consists of
TP-Link Archer AX55 AX3000 4-Stream Wi-Fi 6 Router
TL-SG108PE Smart Switch connected to the above router
TP-Link AP WA 901ND connected to the above switch
All devices on my network either connect to the switch or to the AP wifi
