I stuck this post under an old thread so I though I would just repost it and see if anyone else is experiencing issues similar to this. Using the latest 378.51, I consistently lose my 5GHz signal, but it happens at random times. When I login to the router, go to Wireless, the screen is cut off where I can't access or change anything, which is odd. Every other setting in the router works fine, I just can't access anything under the wireless settings, and I hope it doesn't have anything to do with Bitdefender.
This morning, my 5GHz signal wasn't working, so I logged into the router, copied the syslog (apparently it changed the date on my router too). Here's a small copy of the syslog when it changed the date of my router:
Mar 18 08:20:58 dnsmasq-dhcp[32001]: DHCPSOLICIT(br0) 00:03:00:01:00:1f:29:1a:d1:58
Mar 18 08:22:58 dnsmasq-dhcp[32001]: DHCPSOLICIT(br0) 00:03:00:01:00:1f:29:1a:d1:58
Mar 18 08:24:58 dnsmasq-dhcp[32001]: DHCPSOLICIT(br0) 00:03:00:01:00:1f:29:1a:d1:58
Mar 18 08:26:58 dnsmasq-dhcp[32001]: DHCPSOLICIT(br0) 00:03:00:01:00:1f:29:1a:d1:58
Mar 18 08:28:58 dnsmasq-dhcp[32001]: DHCPSOLICIT(br0) 00:03:00:01:00:1f:29:1a:d1:58
Mar 18 08:30:58 dnsmasq-dhcp[32001]: DHCPSOLICIT(br0) 00:03:00:01:00:1f:29:1a:d1:58
Mar 18 08:32:58 dnsmasq-dhcp[32001]: DHCPSOLICIT(br0) 00:03:00:01:00:1f:29:1a:d1:58
Dec 31 18:00:11 syslogd started: BusyBox v1.20.2
Dec 31 18:00:11 kernel: klogd started: BusyBox v1.20.2 (2015-01-09 00:46:43 EST)
Dec 31 18:00:11 kernel: Linux version 2.6.36.4brcmarm (merlin@mint-dev) (gcc version 4.5.3 (Buildroot 2012.02) ) #1 SMP PREEMPT Fri Jan 9 00:57:53 EST 2015
Dec 31 18:00:11 kernel: CPU: ARMv7 Processor [413fc090] revision 0 (ARMv7), cr=10c53c7f
Dec 31 18:00:11 kernel: CPU: VIPT nonaliasing data cache, VIPT nonaliasing instruction cache
Dec 31 18:00:11 kernel: Machine: Northstar Prototype
Dec 31 18:00:11 kernel: Ignoring unrecognised tag 0x00000000
Dec 31 18:00:11 kernel: bootconsole [earlycon0] enabled
Dec 31 18:00:11 kernel: Memory policy: ECC disabled, Data cache writealloc
Dec 31 18:00:11 kernel: MPCORE found at 19020000
Dec 31 18:00:11 kernel: PERCPU: Embedded 7 pages/cpu @c8215000 s5472 r8192 d15008 u65536
Dec 31 18:00:11 kernel: pcpu-alloc: s5472 r8192 d15008 u65536 alloc=16*4096
Dec 31 18:00:11 kernel: pcpu-alloc: [0] 0 [0] 1
Dec 31 18:00:11 kernel: Built 1 zonelists in Zone order, mobility grouping on. Total pages: 60416
Dec 31 18:00:11 kernel: Kernel command line: root=/dev/mtdblock2 console=ttyS0,115200 init=/sbin/preinit earlyprintk debug
Dec 31 18:00:11 kernel: PID hash table entries: 1024 (order: 0, 4096 bytes)
Dec 31 18:00:11 kernel: Dentry cache hash table entries: 32768 (order: 5, 131072 bytes)
Dec 31 18:00:11 kernel: Inode-cache hash table entries: 16384 (order: 4, 65536 bytes)
Dec 31 18:00:11 kernel: Memory: 128MB 128MB = 256MB total
Dec 31 18:00:11 kernel: Memory: 255540k/255540k available, 6604k reserved, 0K highmem
Dec 31 18:00:11 kernel: Virtual kernel memory layout:
The top 7 lines referring to dnsmasq, goes on more many more times. I didn't feel like filling up a post with the same info. Are those top lines looking for a particular MAC address?
