Router restarts...kernel: brcmboard registered...
tallytr
Latest Merlin FW: 3004.388.8_4
I noticed the router re-boot on its own around every 10-20 days but last 2 days I have seen this message twice at night, the NAS sends me a disconnect email, everything works fine but
the router rebooting?
Also the May 4 date is not right, anyone?
May 4 22:05:07 kernel: brcmboard registered
May 4 22:05:07 kernel: bcmswlpbk0 (Ext switch port: 8) (Logical Port: 8) Virtual link DOWN
May 4 22:05:07 kernel: broadcomThermalDrv brcm-therm: init (CPU count 4 4 4 4)
May 4 22:05:07 kernel: bcmswlpbk0 (Ext switch port: 8) (Logical Port: 8) Virtual link UP
That's the complete log:
My desktop PC I put in sleep mode last night...then right now at 8:10am I put the desktop PC out of sleep mode...
Feb 22 18:01:01 kernel: eth3 (Ext switch port: 2) (Logical Port: 10) (phyId: a) Link DOWN.
Feb 22 18:01:03 kernel: eth3 (Ext switch port: 2) (Logical Port: 10) (phyId: a) Link Up at 10 mbps full duplex
May 4 22:05:07 kernel: eth5 (Ext switch port: 7) (Logical Port: 15) (phyId: c) Link Up at 1000 mbps full duplex
May 4 22:05:08 kernel: eth0 (Int switch port: 3) (Logical Port: 3) (phyId: 1e) Link Up at 2500 mbps full duplex
May 4 22:05:10 kernel: eth3 (Ext switch port: 2) (Logical Port: 10) (phyId: a) Link Up at 10 mbps full duplex
May 4 22:05:10 kernel: eth4 (Ext switch port: 3) (Logical Port: 11) (phyId: b) Link Up at 1000 mbps full duplex
Feb 23 08:10:43 kernel: eth3 (Ext switch port: 2) (Logical Port: 10) (phyId: a) Link DOWN.
Feb 23 08:10:45 kernel: eth3 (Ext switch port: 2) (Logical Port: 10) (phyId: a) Link Up at 1000 mbps full duplex
Did you modify the default log level by chance?
You're missing lots of startup messages. If you're using Merlin's firmware I suggest you change System Log - General Log > Log only messages more urgent than to "All".
Or are you using an addon script like Scribe which mangles the syslog?
The default log level is notice/debug as I remember. The reason for missing logs.
This this? Not using an addon script.
Now you have to wait for this issue to happen again so you can eventually see what is causing it.
ooooh, so much stuf here, is that normal? Just keep scrolling ;-) Using noIP for DDNS...
23 08:58:01 ddns: eth0 has not yet obtained an WAN IPv6 address.(8)
Feb 23 08:58:01 ddns: IP address, server and hostname have not changed since the last update.
Feb 23 08:58:31 watchdog: start ddns.
Feb 23 08:58:31 ddns: eth0 has not yet obtained an WAN IPv6 address.(7)
Feb 23 08:58:31 ddns: IP address, server and hostname have not changed since the last update.
Feb 23 08:59:01 watchdog: start ddns.
Feb 23 08:59:01 ddns: eth0 has not yet obtained an WAN IPv6 address.(6)
Feb 23 08:59:01 ddns: IP address, server and hostname have not changed since the last update.
Feb 23 08:59:31 watchdog: start ddns.
Feb 23 08:59:31 ddns: eth0 has not yet obtained an WAN IPv6 address.(5)
Feb 23 08:59:31 ddns: IP address, server and hostname have not changed since the last update.
Feb 23 09:00:01 watchdog: start ddns.
Feb 23 09:00:01 ddns: eth0 has not yet obtained an WAN IPv6 address.(4)
Feb 23 09:00:01 ddns: IP address, server and hostname have not changed since the last update.
This is unrelated to your reboot issue.
I believe that DDNS problem has been reported many times. I didn't pay too much attention to the posts as I don't have IPv6.
I also don't use IPv6. Asus DDNS has ongoing issues with IPv6. There is an option to disable IPv6 update in DDNS settings.
The May 4th date is what your router shows before the router obtains an updated date/time from an NTP time server. It's normal.
Disabled IpV6 update in DDNS settings
