RMinNJ
Which antennas did you get ?I replaced the antennas with normal looking 7-8 inch ones. Looks 10X better, better swiveling/repositioning and performs just as well, maybe even a dBm or 2 better anywhere around the house.
I'm not sure where I got them from as I had them in drawer for ages. I may have gotten them to replace smaller antennas on some router at one time. They are about 8 inches end to tip. They look like the typical round body antennas with a tapered tip you can get on Amazon/ebay.Which antennas did you get ?
- No fans or anything extra used for ventilation, in a (5-side) closed wooden cabinet.@Kees17760
Good score on the 6000!
Two technical questions regarding your setup:
- Do you have something to move the air in/out of your shelving for ventilation?
- Are you utilizing name brand or generic toothpaste lids?
LOL ..the one review of them says 50% faster. One would think not having all the plastic on the AX6000 ones to go through woud help...I was actually going to give these a try before I found the ones I have. They look exactly the same as the ones I'm using ...
https://www.amazon.com/dp/B07XMB9PST/?tag=snbforums-20
I even tried the ones off an old dlink dir-880L, same length, but that one only had 3 antennas. Those worked just as well mixed in with the other generic ones.
I'm sure Bingfu has done diligent research
The plastic is effectively transparent at the RF used.LOL ..the one review of them says 50% faster. One would think not having all the plastic on the AX6000 ones to go through woud help.
That's gotta be it .. the red plastic performing better. I think if one sets the RGB to only red one gets 50% more 5Ghz range....Asus uses special gaming plastic.![]()
for a moment, I thought that pic was a joke... that's actually a real device/color?... please kill me now...
Have you seen this high performance RT-AX86U model?
I'm just waiting for this to come as Pro and getting one.
Welcome To SNBForums
