Router with best QOS ?
I have a question for you that I haven't been able to get an answer let's see if you can help. So on paper the netgear x8 has faster 2.4 1000mb and 5ghz 2.2gb (both with 1024 qam) vs netgear x10
What program is that?
Facebook is a bit longer... but most gamers there...
Netflix... must appreciate CDN's perhaps...
I have a question for you that I haven't been able to get an answer let's see if you can help. So on paper the netgear x8 has faster 2.4 1000mb and 5ghz 2.2gb (both with 1024 qam) vs netgear x10 800mb vs 1733gb (with 200 something qam) would I see a difference in wireless speeds with the x8 vs the x10 or would the device have to support 1028 qam or see no difference because of saturation.
None of the above... but I'd take the X10 over the X8 if I had a choice between the two...
Really my curiosity says to me I should pick one up for testing. I would think with the increase modulation and max speeds you would see that in wireless speeds
My network is flat and fast... Yes, smokeping*, host there, it's in the core, I have two layers on my network...
* there's some concerns about smokeping, but results with current are sound...
