I have dual wan configuration with load balancing. It screws the internet connection normally, but I use it with routing table. My home setup was
x.x.x.2 - x.x.x.63 addresses were reserved to fixed IP devices
x.x.x.64 - x.x.x.127 to dhcp
Even addresses are routed to wan1 and odd to wan2. I had exactly 128 entries in routing table.
This has been working at least in 380.x, but I noticed today (382.x) that all addresses were routed to wan1. I tried to fix it without success. Dropped entries down to 64, but no luck. I'm using gui.
I decided to reset to factory settings. Then I entered 64 entries (as the new fw limit for routing table entries has changed from 128 to 64) to routing table, but device didn't save them. Just showed up an "success" popup and returned to empty routing table. Then I tried to add routes small bunch at time and found out maximum routes I can enter to my device is 51. Checked log and trying to add even one gives error:
"Dec 7 22:31:32 httpd: nvram_check fail: nvram wans_routing_rulelist over length (1028 > 1024)"
I'd like to have more entries in routing table. Is there any configuration option for that?
My router is RT-AC88U.
Kai
Kai
