Jul 27 01:34:10 syslog: wlceventd_proc_event(494): eth1: Deauth_ind 08:8E:DC:D5:0E:EC, status: 0, reason: Disassociated due to inactivity (4), rssi:0
Jul 27 01:34:22 syslog: wlceventd_proc_event(530): eth1: Auth 08:8E:DC:D5:0E:EC, status: Successful (0), rssi:0
Jul 27 02:12:06 WATCHDOG: [FAUPGRADE][auto_firmware_check:(7784)]do webs_update
Jul 27 02:12:17 WATCHDOG: [FAUPGRADE][auto_firmware_check:(7802)]retrieve firmware information
Jul 27 02:12:17 WATCHDOG: [FAUPGRADE][auto_firmware_check:(7817)]fimrware update check first time
Jul 27 02:12:17 WATCHDOG: [FAUPGRADE][auto_firmware_check:(7848)]no need to upgrade firmware
Jul 27 02:12:47 WATCHDOG: [FAUPGRADE][auto_firmware_check:(7784)]do webs_update
Jul 27 02:12:47 WATCHDOG: [FAUPGRADE][auto_firmware_check:(7802)]retrieve firmware information
Jul 27 02:12:47 WATCHDOG: [FAUPGRADE][auto_firmware_check:(7822)]fimrware update check once
Jul 27 02:13:17 WATCHDOG: [FAUPGRADE][auto_firmware_check:(7784)]do webs_update
Jul 27 02:13:17 WATCHDOG: [FAUPGRADE][auto_firmware_check:(7802)]retrieve firmware information
Jul 27 02:13:17 WATCHDOG: [FAUPGRADE][auto_firmware_check:(7822)]fimrware update check once
Jul 27 02:13:47 WATCHDOG: [FAUPGRADE][auto_firmware_check:(7784)]do webs_update
Jul 27 02:13:47 WATCHDOG: [FAUPGRADE][auto_firmware_check:(7802)]retrieve firmware information
Jul 27 02:13:47 WATCHDOG: [FAUPGRADE][auto_firmware_check:(7817)]fimrware update check first time
Jul 27 02:13:47 WATCHDOG: [FAUPGRADE][auto_firmware_check:(7848)]no need to upgrade firmware
Jul 27 02:23:08 rc_service: rc 1419:notify_rc restart_wrs
Jul 27 02:23:33 BWDPI: fun bitmap = 4df
Jul 27 02:23:33 A.QoS: qos_count=0, qos_check=0
Jul 27 03:31:10 syslog: wlceventd_proc_event(494): eth1: Deauth_ind 08:8E:DC:D5:0E:EC, status: 0, reason: Disassociated due to inactivity (4), rssi:0
Jul 27 03:31:15 syslog: wlceventd_proc_event(530): eth1: Auth 08:8E:DC:D5:0E:EC, status: Successful (0), rssi:0
Jul 27 05:06:32 ahs: [read_json]Update ahs JSON file.
Jul 27 05:17:10 syslog: wlceventd_proc_event(494): eth1: Deauth_ind 08:8E:DC:D5:0E:EC, status: 0, reason: Disassociated due to inactivity (4), rssi:0
Jul 27 05:17:12 syslog: wlceventd_proc_event(530): eth1: Auth 08:8E:DC:D5:0E:EC, status: Successful (0), rssi:0
### ME FIXING IT ###
Jul 27 07:28:50 rc_service: httpd 578:notify_rc restart_wan_if 0;restart_stubby
Jul 27 07:28:57 wan: finish adding multi routes
Jul 27 07:28:58 miniupnpd[4761]: shutting down MiniUPnPd
Jul 27 07:29:00 syslog: it is advised to use network interface name instead of 192.168.1.1/255.255.255.0
Jul 27 07:29:00 miniupnpd[32337]: HTTP listening on port 57367
Jul 27 07:29:00 miniupnpd[32337]: Listening for NAT-PMP/PCP traffic on port 5351
Jul 27 07:29:11 rc_service: httpd 578:notify_rc restart_wan_if 0;restart_stubby
Jul 27 07:29:19 wan: finish adding multi routes
Jul 27 07:29:20 miniupnpd[32337]: shutting down MiniUPnPd
Jul 27 07:29:21 syslog: it is advised to use network interface name instead of 192.168.1.1/255.255.255.0
Jul 27 07:29:21 miniupnpd[32540]: HTTP listening on port 42159
Jul 27 07:29:21 miniupnpd[32540]: Listening for NAT-PMP/PCP traffic on port 5351
Jul 27 07:29:26 kernel: *** ERROR: [tdts_shell_ioctl_sig_op_load:95] tdts_core_rule_parsing_trf_load() fail!
Jul 27 07:29:28 BWDPI: fun bitmap = 4df
Jul 27 07:29:28 A.QoS: qos_count=0, qos_check=0
Jul 27 07:29:34 dhcp client: bound 108.162.167.137/255.255.255.224 via 108.162.167.129 for 3578 seconds.
Jul 27 07:29:35 BWDPI: fun bitmap = 4df
Jul 27 07:29:35 A.QoS: qos_count=0, qos_check=0
Jul 27 07:29:35 kernel: ERR[parse_qos_conf:939] Can't set new QoS conf while QoS is started!
Jul 27 07:29:35 kernel: ERR[ioctl_iqos_op_config:3608] parse qos_conf error!!
Jul 27 07:29:35 kernel: ioctl_iqos_op_config() fail!
Jul 27 07:29:35 A.QoS: set_qos_conf fails
Jul 27 07:29:35 A.QoS: restart A.QoS because set_qos_conf / set_qos_on / setup rule fail
Jul 27 07:29:36 A.QoS: qos_count=0, qos_check=1
Jul 27 07:29:40 A.QoS: qos rule is less than 22
Jul 27 07:29:40 A.QoS: restart A.QoS because set_qos_conf / set_qos_on / setup rule fail
Jul 27 07:29:41 dhcp client: bound 108.162.167.137/255.255.255.224 via 108.162.167.129 for 3578 seconds.
Jul 27 07:31:18 rc_service: cfg_server 3987:notify_rc restart_qos;restart_firewall;
Jul 27 07:31:45 BWDPI: fun bitmap = 45f
Jul 27 07:41:10 syslog: wlceventd_proc_event(494): wl0.1: Deauth_ind D6:E1:0E:44:EA:BA, status: 0, reason: Disassociated due to inactivity (4), rssi:0
Jul 27 07:41:12 syslog: wlceventd_proc_event(530): wl0.1: Auth D6:E1:0E:44:EA:BA, status: Successful (0), rssi:0
Jul 27 07:41:13 syslog: wlceventd_proc_event(530): wl0.1: Auth D6:E1:0E:44:EA:BA, status: Successful (0), rssi:0
Jul 27 07:41:13 syslog: wlceventd_proc_event(559): wl0.1: Assoc D6:E1:0E:44:EA:BA, status: Successful (0), rssi:0
