RT-AC1900P无线中继
Wireless drivers come from Asuswrt. If you believe Asuswrt-Merlin 386.9 and 386.10 have better Wi-Fi than previous versions - the possible reason is newer Asuswrt base used with newer Wi-Fi drivers. Asuswrt-Merlin 386.9 and 386.10 are based on GPL 386_50757. There is even newer released Asuswrt 386_51255 and 386_51529. Have you tried stock Asuswrt? It perhaps has the same better Wi-Fi.
If you continue writing in Chinese you may get banned. You use translation instead before posting. Thank you!
Thank you for your kind reminder that the beta version of WiFi will not experience weak jumps when using Douyin in the bathroom like the historical version. From what you say, is it another branch? I want to have better WiFi penetration, can you tell me where to download and try?
Latest firmware for RT-AC1900P is here:
This firmware is newer than available Asuswrt-Merlin. May work well on your router as Repeater.
This is the official firmware, 5G wall penetration is not as stable as the beta version. 386, especially the wireless relay, is super unfriendly to mobile light modem and routing all-in-one machines. Using 386 firmware will cause mobile phone music software to fail to play online without loading and responding, resulting in flashbacks. Shopping apps cannot load pictures and prompts to close without responding. 385 The firmware does not have the problem of strong destructive power of the 386 wireless relay. The firmware of the 385 will fail to connect to the signal after a long time, and restarting is useless. It is very disappointing to recommend the official one.
If it is a China Mobile optical modem router all-in-one machine, use the official 386 firmware for wireless relay, and directly close the mobile shopping software and music software without any response. Video software such as Douyin Kuaishou is fine, and the official 385 has no problems. The only problem is that after a long time, the mobile phone cannot connect to WiFi, and restarting cannot solve the problem. It must be restored to factory settings. Seeing the official firmware is scary, there is no version that is easy.
翻译类型​
文字
网站
文本翻译​
中文(简体) - 检测到的语言
swap_horiz
英语
原文​
如果是中国移动光猫路由器一体机,使用官方386固件无线中继,我打开一个软件就被卡主不动,或者是打开软件后无加载后提示无响应闪退等问题,首先我确认手机是没问题的,直连中国移动光猫路由器一体机确认也是没有网络问题的,就因为官方386固件,我怀疑手机是不是要接近坏掉了,官方386的固件太可怕了,像384,385的无线中继不会引起手机软件卡在打开空白页引起长时间打不开软件,或者打开软件后无响应闪退,我以为手机老化要坏了,原来是386的无线中继问题,太可怕了。
clear
Rúguǒ shì zhōngguó yídòng guāng māo lùyóuqì yītǐ jī, shǐyòng guānfāng 386 gùjiàn wúxiàn zhōng jì, wǒ dǎkāi yīgè ruǎnjiàn jiù bèi kǎ zhǔ bù dòng, huòzhě shì dǎkāi ruǎnjiàn hòu wú jiāzài hòu tíshì wú xiǎngyìng shǎn tuì děng wèntí, shǒuxiān wǒ quèrèn shǒujī shì méi wèntí de, zhí lián zhòng guó yídòng guāng māo lùyóuqì yītǐ jī quèrèn yěshì méiyǒu wǎngluò wèntí de, jiù yīnwèi guānfāng 386 gùjiàn, wǒ huáiyí shǒujī shì bùshì yào jiējìn huài diàole, guānfāng 386 de gùjiàn tài kěpàle, xiàng 384,385 de wúxiàn zhōng jì bù huì yǐnqǐ shǒujī ruǎnjiàn kǎ zài dǎkāi kòngbái yè yǐnqǐ cháng shíjiān dǎ bù kāi ruǎnjiàn, huòzhě dǎkāi ruǎnjiàn hòu wú xiǎngyìng shǎn tuì, wǒ yǐwéi shǒujī lǎohuà yào huàile, yuánlái shì 386 de wúxiàn zhōng jì wèntí, tài kěpàle.
展开
227 / 5,000
翻译结果​
翻译结果​
star_border
If it is an all-in-one China Mobile optical modem router, using the official 386 firmware wireless relay, if I open a software, the card owner will not move, or after opening the software, it will prompt no response and flash back after the software is loaded. First, I confirm that the phone is There is no problem. It is confirmed that there is no network problem when directly connected to the China Mobile optical modem router all-in-one machine. Because of the official 386 firmware, I doubt whether the mobile phone is close to breaking down. The official 386 firmware is terrible, like 384, 385 The wireless relay will not cause the mobile phone software to be stuck on a blank page and cause the software to be unable to open for a long time, or there will be no response and flashback after opening the software. I thought the phone was aging and would be broken. It turned out to be a problem with the wireless relay of the 386, which is terrible. .
I'm sorry, I don't understand what exactly problem you have or trying to solve.
對不起,我不明白你到底有什麼問題或者試圖解決什麼問題。
好吧,我敢肯定,在這個代人中,我們都會有
101 / 5,000
star_border
You are right, no need to apologize, ASUS official 386 wireless relay cannot use China Mobile’s broadband network, such as shopping software, music software, because the network is not normal, causing freezes and flashbacks, using Douyin, Kuaishou video software network is not Smooth and normal without any abnormalities. 385 firmware does not have such a problem
