RT AC3100 386.13 vs 386.14
sharmay
RT-AC3100 in access point mode (hardwired)
I have custom certs installed which are still active. After upgrading to 386.14386.14 web is using auto generated certs instead of one I have uploaded. When I revert back to 386.13 correct certs are used.
I have not seen any thing in log for this.
Any suggestions?
I have reviewed link postS but not helpful in my case. My uploaded cert is a valid letsencrypt cert. Same one work on AX88U.
This seems to work (not sure if it is a permanent fix):
ssh to ac3100
cp /jffs/.cert/key.pem /tmp/etc/key.pem
cp /jffs/.cert/cert.pem  /tmp/etc/cert.pem
service restart_httpd
service restart_httpds
Any better approaches?
sharmay, I have a similar configuration an AX88U router and retained my ac3100 as a legacy access point. I encountered this problem, too, and was able to resolve it with your above procedure. I appreciate your posting this solution, as I would never have come up with it on my own. Thanks.
