RT-AC3100 Available in UK
Good to hear. I'm hoping mine is designed for EU region since it apparently comes with a AUSSIE, EU and UK plug.
only problem i have so fare is ftp is not working with merlin alpha build
All fixed I fine a reset on the router and all's good
s
I got mine on Monday from the same company it does indeed come with all three plugs, the power adapter is 19v 3.42A. I'm running RMerlin's alpha firmware and all seems good with BT Infinity. All my devices have connected fine :). Mine came in at £246 delivered including £45 customs/duty charge.
s
Great to hear. Mine is in the Midlands at the moment so hopefully delivered Tomorrow but since the estimated delivery says Tuesday might not be until then.
Damn it... Does it mean I was better off to wait for EU version of the router? Possible that European devices may not even see 5 ghz ssid?
I have an American version of ac88u incoming in a couple of days to Ireland...
5Ghz channel 36, 40, 44, 48 is available in most regions that I know about. If you buy a router from another region like I did and want to stay legal in your area and want to be able to connect all your devices - set the 5Ghz channel to any of these channels in the Wireless settings not Auto. This would apply for the 2.4Ghz as well because some regions don't have channel 12-14 so set the channel to 1-11 in Wireless settings not Auto.
A question to the specialists on this forum ..... when doing a crash recovery don't you reinstall everything including the bootloader ? If that is the case I could use a CD from my own region and get the correct region coding or is there different hardware for different regions?
The bootloader is not touched by a firmware flash. The bootloader is your safety net in case of a failed flash - it what allows you to recover.
So there is no way to replace the bootloader ?
Router came today and everything is working correctly, did indeed come with a UK plug.
What channels do you have available on the 5ghz?
Sent from my LG-D855 using Tapatalk
Here you go.
Cool mate the same channels that I can get only the lower ones work on all 5ghz devices only my laptop works on higher
I have mine on 44 just know working all fine are you using Merlin firmware or stock asus?
I can't use stock as need the wan special that's in Merlin firmware to connect to sky fibre
i am using alpha 4 now running fine remember to do a reset if upgrading set up one hard drive to run deluge as a torrent client and the other connected as a media server
