Wingsfan87
Is this possible? In Router mode you have the option under Lan > Switch Control. However soon as I switch it to AP mode this disappears as a GUI option. If yes, what is the command line in can run via SSH to enable it in AP mode?
Devices:
Gateway/Main Router - AC5300 ver 380.65.2
AP - AC3100 380.65.2
Switch - Cisco SG200-26 running LACP on 2 x 2 ports
Setup:
Main Router is using the LACP/Link Agg option to run to switch on ports 1 and 2. Switch is configured to have those 2 ports for teaming with LACP. Checked status on switch and and it shows LACP is active with both ports. AP is on ports 3 and 4 of the switch and running to ports 1 and 2 on the AP. Before I turned on AP mode I turned on LACP mode in the router mode. After turning on AP mode I check the switch management page and the first router is still working great with LACP active on ports 1 and 2. But ports 3 and 4 show only 1 active and 1 passive so LACP isn't enabled anymore on AP I am guessing. How would I check this via SSH command line for status and how would I turn it on?
Devices:
Setup:
