[RT-AC3100] - Transmission error Install
elrengo
Hi! I bought a Asus RT-AC3100 router. Yesterday I installed the AsusWRT-Merlin Firmware (Stable Release: 380.58).
I have attached to router 2 HDD. First in USB3 a Sonny 1TB (USB3), second in USB2 a old laptop 500GB using a Kingstong enclosure.
In Sony I shared media to my Network, at this moment only fotos.
In other I create 2 filesystem, 1 GB Swap file system then EXT4 file system to install entware, transmission or other software and for the files download by torrent.
I follow the wiki to install entware and transmission:
1. https://github.com/RMerl/asuswrt-merlin/wiki/Entware
2. https://github.com/RMerl/asuswrt-merlin/wiki/Installing-Transmission-through-Entware
That was imposible to found how to enable swapon for swap file system I follow the step to create a swap file and enable it.
And I enable the "JFFS Partition" and "Enable JFFS custom scripts and configs" then formtat them after restart.
When I finish the intall and go to browser: 192.168.1.1:9091 I fown this error:
404: Not Found
Couldn't find Transmission's web interface files!
Users: to tell Transmission where to look, set the TRANSMISSION_WEB_HOME environment variable to the folder where the web interface's index.html is located.
Package Builders: to set a custom default at compile time, #define PACKAGE_DATA_DIR in libtransmission/platform.c or tweak tr_getClutchDir () by hand
Command result:
elrengo@RT-AC3100:/tmp/mnt/download/entware/etc/transmission# uname -a
Linux RT-AC3100 2.6.36.4brcmarm #1 SMP PREEMPT Sun Mar 20 16:07:50 EDT 2016 armv7l GNU/Linux
elrengo@RT-AC3100:/tmp/mnt/download/entware/etc/transmission# mount
rootfs on / type rootfs (rw)
/dev/root on / type squashfs (ro,relatime)
devtmpfs on /dev type devtmpfs (rw,relatime,size=257528k,nr_inodes=64382,mode=755)
proc on /proc type proc (rw,relatime)
tmpfs on /tmp type tmpfs (rw,relatime)
sysfs on /sys type sysfs (rw,relatime)
devpts on /dev/pts type devpts (rw,relatime,mode=600)
/dev/mtdblock4 on /jffs type jffs2 (rw,noatime)
usbfs on /proc/bus/usb type usbfs (rw,relatime)
/dev/sda2 on /tmp/mnt/download type ext4 (rw,nodev,relatime,user_xattr,barrier=1,data=ordered)
/dev/sdb1 on /tmp/mnt/Fotos type tntfs (rw,nodev,relatime,uid=0,gid=0,umask=00,nls=utf8,min_prealloc_size=64k,max_prealloc_size=256M,readahead=1M,user_xattr,case_sensitive,fail_safe,hidden=show,dotfile=show,errors=continue,mft_zone_multiplier=1)
elrengo@RT-AC3100:/tmp/mnt/download/entware/etc/transmission# df
Filesystem 1K-blocks Used Available Use% Mounted on
/dev/root 37120 37120 0 100% /
devtmpfs 257528 0 257528 0% /dev
tmpfs 257672 632 257040 0% /tmp
/dev/mtdblock4 65536 1752 63784 3% /jffs
/dev/sda2 451922072 570464 427247008 0% /tmp/mnt/download
/dev/sdb1 976759804 48543112 928216692 5% /tmp/mnt/Fotos
[/quote]elrengo@RT-AC3100:/tmp/mnt/download/entware/etc/transmission# free
total used free shared buffers
Mem: 515348 122664 392684 0 660
-/+ buffers: 122004 393344
Swap: 524284 0 524284
elrengo@RT-AC3100:/tmp/mnt/download/entware/etc/transmission#[/quote]
At the end I found after a reboot when I type cd /opt intead of go to 500GB HDD wehere I instaled entware go to photo HDD with NTFS. How is possible to do a scratch install again and delete entware, transsmision, swap configuration and firewall configuration.
Thanks in advance!
