RT-AC3100 with latest firmware. Nothing but bugs!! No support at all!
when i finally get it to work, after a few minutes i get the exclamation point on the ethernet icon on my tray. when i check the error that is what i get.
ok so I updated to the latest firmware but now, after a few hours I lose wifi connectivity. I only connect via lan with no prolem. So I did a restore on it, thinking of loading Merlin firmware, any thoughts ? thxs
Using a RT-AC3100 here and its rock solid on there latest firmware. In fact i have not had problems with any firmware and this router. I did buy mine back in November of 2015 its one of the first and originals i think they have newer revisions of the 3100 now and i am glad i got the old one.
Hi
im thinking one when i did the firmware update i had an error on the download, secondly i might have a bad setting on my wifi?
Sent from my SM-G935V using Tapatalk
ok so i loaded the latest firmware , 2.4 mhz doesnt work. i enable it settings and doesnt show up. 5.0 no problem. any ideas?
speaking of which, is there any reason my media bridge RT-AC3100 doesn't work like, once in a while and I have to enter its config page and reboot it? Also worth mentioning is that this AC3100 is a newer revision and my router AC3100 is 2015-era revision.
It doesn't happen too often, seems like every 2 weekish or so?
Wonder if i'm missing something here, maybe my problem is a bit too vague to explain it fully.
On Merlin 380.66_4 for both new revision media bridge and old revision router.
Apologies if I missed that you've already tried this, but have you tried Resetting to Factory Defaults?
IMO, it's the most important step to try when problems are encountered.
Thanks for your answers. I was told by ASUS about the warranty thing. Probably depends on who you talk to there.
So does the bandwidth limiter possible work in 380_3941?
hi so this is 6 versions behind? i know the latest is not working for me. thxs
