D
Deleted member 22229
Guest
Can someone post there AC3100 cpu and radio temps ?
2.4-43c, 5g-47c, cpu 79
Could you check and see if your parental controls are working? Click the sex check box and let me know if it does block. It is not working on merlins new .57 preview.Thanks i was hoping the CPU would be less. The radios look great.![]()
I can't check myself at the moment. But I'm pretty sure Merlin is running on a AC88U, and we're using the AC3100. Other then the 4 extra lan ports they're supposed to be the same. However this alpha build for the AC3100 seems to have a couple bugs, as I can't even set the wireless channel's for both bands.Could you check and see if your parental controls are working? Click the sex check box and let me know if it does block. It is not working on merlins new .57 preview.
I ended up switching to Open DNS for now to filter my kids tablets.I can't check myself at the moment. But I'm pretty sure Merlin is running on a AC88U, and we're using the AC3100. Other then the 4 extra lan ports they're supposed to be the same. However this alpha build for the AC3100 seems to have a couple bugs, as I can't even set the wireless channel's for both bands.
I think I am just going to wait a while for a stable build from merlinI had to go back to the latest official Asus build for now. As Merlin's alpha2 build just a bit to buggy for me to run now. Applying wireless settings on the general tab is just broken currently. I tried everything from multiple browsers, to factory resets. Either way, I wasn't expecting Merlin to even have a build ready at this point. Anyways this isn't a complaint by any means, more of an update.
I was wondering if there something I can change in settings?
Sent from my SAMSUNG-SM-G920A using Tapatalk
O don't think I can use 5Ghz with laptop since I can't find it only 2.4The only thing i can think of and this only apply's to the 5 Ghz band is using the higher channels they put out much more power then the low ones.
I went from a 68P to the 3100. 5ghz signal strength is no different. However, speed and stability do seem better.How does the 5GHz on this device compare to that of the AC68U, does it blast it out of the water or not given the inherent limitations of this wavelength?
Asuswrt-Merlin preview release for the RT-AC3100 has been updated, which should resolve its webui-related issues.
What are the telnet commands to check these temps?Can someone post there AC3100 cpu and radio temps ?
Thread starter | Title | Forum | Replies | Date |
D | RT-AC3100 Issue with Visual Studio Connection | ASUS AC Routers & Adapters (Wi-Fi 5) | 11 | |
K | AC3100 Bricked After Power Off – Need Help | ASUS AC Routers & Adapters (Wi-Fi 5) | 5 |
Welcome To SNBForums
